Bradley
- 2
Can I convert an electric log spliter and use the hydrolic to create a dump lift? Using my truck and its 12 volt battery
It wouldn't be exactly a "switch". You would need a hydraulic manifold that redirects the oil flow from the spitter to a new ram mounted to your dumping frame. Either that or a mechanical linkage with some kind of "clutch' so you can use the ram directly but only when you want it. That's if I'm understanding that you want to keep the splitter intact. To use the hydraulics without the splitter, there should be no problem at all.Bradley said:I really don't no much about it I seen the logsplitters at harbor freight and I thought I might be able to inaert the eletric motor and hydraulic in the bed of my truck and hookup a switch in the cab to run the hydraulic to dump just a thought
Technically, it is possible to convert an electric log splitter into a dump lift with the right modifications. However, it is not recommended as it can be dangerous and may not function as efficiently as a purpose-built dump lift.
The modifications required will depend on the specific log splitter and dump lift models. Generally, you will need to add a lifting mechanism, such as a hydraulic cylinder, and reinforce the frame to handle the weight of a load. You may also need to modify the control system and add safety features.
It may seem like a cost-effective solution, but in reality, it can end up being more expensive than purchasing a dedicated dump lift. The cost of materials, labor, and potential safety concerns can add up quickly. It is best to compare the costs and benefits before making a decision.
Yes, there are several safety concerns to consider. The modifications may affect the stability and balance of the machine, making it more prone to tipping over. There may also be risks of hydraulic leaks or malfunctions if not installed properly. It is essential to thoroughly understand the safety precautions and have the necessary skills and knowledge before attempting a conversion.
It is not recommended to use a converted electric log splitter as a dump lift for heavy loads. The original log splitter may not have been designed to handle heavy loads, and the added modifications may not provide enough support. It is best to use a purpose-built dump lift for heavy loads to ensure safety and efficiency.
