MHB Can I Graph a Semicircle By Hand?
  • Thread starter Thread starter mathdad
To graph a semicircle by hand from the equation (x - 4)² + (y - 1)² = 9, first isolate y to find the upper semicircle. The center of the circle is at (4,1) with a radius of 3, leading to three key points: (7,1), (4,4), and (1,1). These points represent the semicircle's boundaries, located 3 units away from the center in the respective directions. After plotting these points, connect them with a circular arc to complete the semicircle. This method allows for accurate hand-drawing without needing graphing software.
mathdad
An equation of the circle is given below. Solve the equation for y, and then graph the resulting semicircle.
(x - 4)^2 + (y - 1)^2 = 9
I must isolate y. I get it. My question concerns graphing the semicircle by hand. Can it be graphed by hand or should I simply use the wolfram math site for graphing? If by hand, can you provide several points that would allow me to draw the semicircle correctly?
Mathematics news on Phys.org
You know the center of the circle is $(4,1)$ amd the radius is $r=3$. So, this gives you 3 easy points (if you choose the "upper" semi-circle):
$(4+3,1)=(7,1))$
$(4,1+3)=(4,4)$
$(4-3,1)=(1,1)$
Then connect the 3 points with a circular arc.
$(4+3,1)=(7,1))$
$(4,1+3)=(4,4)$
$(4-3,1)=(1,1)$
Plotting the three points is easy but I am slightly confused in terms of how you came up with the points.
The first point is 3 units to the right of the circle's center, the second point is 3 units up and the third point is 3 units to the left. :D
I totally get it. Thanks again.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
