Can I put radio buttons above an ImageView in a ScrollView?
To place radio buttons above an ImageView in a ScrollView, using a RelativeLayout is recommended, allowing the radio buttons to be positioned with the android:layout_above attribute. Alternatively, a LinearLayout can be utilized with the android:layout_weight attribute to manage the height distribution between the ImageView and radio buttons. A FrameLayout can also be considered, using the android:layout_gravity attribute for positioning. It’s essential to experiment with different layouts and attributes to achieve the desired formatting without hardcoding dimensions. This approach ensures compatibility across various phone models while maintaining a visually appealing menu screen.
Darkmisc
TL;DR Summary
I'd like to set an ImageView as the background for radio buttons. It only works if I hardcode the width and height of the ImageView. If I set the height and width to "match_parent", the ImageView is visible, but not the radio buttons.
Hi everyone
I'd like to set an ImageView background for a menu screen that uses ScrollView, ConstrainedLayout and Radio Buttons. This is possible if I hardcode the width and height of the ImageView, but I don't want to do this because it might ruin the formatting on some models of phone.
I'd like to set the dimensions to "match_parent" or "wrap_content", but if I do this, only the ImageView is visible. The Radio Buttons aren't visible at all.
Is there a way around this? I've tried putting the code for the ImageView inside the Radio Group, and it doesn't help.
My xml code for the menu is below.
Thanks
[CODE lang="java" title="menu"]<?xml version="1.0" encoding="utf-8"?><ScrollView
xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:layout_width="match_parent"
android:layout_height="wrap_content"
android:layout_weight = "1"
tools:layout_editor_absoluteX="1dp"
tools:layout_editor_absoluteY="1dp"
android:fillViewport="true"> <androidx.constraintlayout.widget.ConstraintLayout
tools:context=".Menu">
<ImageView
android:id="@+id/imageView1"
android:layout_width="400dp"
android:layout_height="400dp"
app:layout_constraintBottom_toBottomOf="parent"
app:layout_constraintEnd_toEndOf="parent"
app:layout_constraintStart_toStartOf="parent"
app:layout_constraintTop_toTopOf="parent"
android:scaleType="centerCrop"
android:layout_alignParentLeft="true"
android:layout_alignParentTop="true" android:src="@drawable/cherry"/> <TextView
android:id="@+id/textView"
android:text="Choose characters" />
<RadioGroup
app:layout_constraintTop_toTopOf="parent">
<CheckBox
android:id="@+id/a"
android:text="ア a イ i ウ u エ e オ o" />
<CheckBox
android:id="@+id/k"
android:text="カ ka キ ki ク ku ケ ke コ ko キャ kya キュ kyu キョ kyo
<CheckBox
android:id="@+id/s"
android:text="サ sa シ shi ス su セ se ソ so シャ sha シュ shu ショ sho
<CheckBox
android:id="@+id/ta"
android:text="タ ta チ chi ツ tsu テ te ト to チャ cha チュ chu チョ cho" />
<CheckBox
android:id="@+id/na"
android:text="ナ na ニ ni ヌ nu ネ ne ノ no ニャ nya ニュ nyu ニョ nyo" />
<CheckBox
android:id="@+id/h"
android:text="ハ ha ヒ hi フ fu ヘ he ホ ho ヒャ hya ヒュ hyu ヒョ hyo" />
<CheckBox
android:id="@+id/m"
android:text="マ ma ミ mi ム mu メ me モ mo ミャ mya ミュ myu ミョ myo" />
<CheckBox
android:id="@+id/y"
android:text="ヤ ya ユ yu ヨ yo" />
<CheckBox
android:id="@+id/r"
android:text="ラ ra リ ri ル ru レ re ロ ro リャ rya リュ ryu リョ ryo" />
<CheckBox
android:id="@+id/wa"
android:text="ワ wa" />
<CheckBox
android:id="@+id/n"
android:text="ン n" /> <CheckBox
android:id="@+id/g"
android:text="ガ ga ギ gi グ gu ゲ ge ゴ go ギャ gya ギュ guy ギョ gyo" />
<CheckBox
android:id="@+id/z"
android:text="ザ za ジ ji ズ zu ゼ ze ゾ zo ジャ ja ジュ ju ジョ jo" />
<CheckBox
android:id="@+id/d"
android:text="ダ da ヂ (ji) ヅ (zu) デ de ド do" />
<CheckBox
android:id="@+id/b"
android:text="バ ba ビ bi ブ bu ベ be ボ bo ビャ bya ビュ byu ビョ byo" />
<CheckBox
android:id="@+id/p"
android:text="パ pa ピ pi プ pu ペ pe ポ po ピャ pya ピュ pyu ピョ pyo" />
<CheckBox
android:id="@+id/f"
android:text="ファ fa フィ fi フェ fe フォ fo" />
<CheckBox
android:id="@+id/t"
android:text="ツァ tsa ティ ti トゥ tu" />
<CheckBox
android:id="@+id/w"
android:text="ウェ we ウォ wo" />
<CheckBox
android:id="@+id/all"
android:text="all" /> </RadioGroup>
<Button
android:id="@+id/button"
android:layout_width="wrap_content"
android:text="Button"
android:onClick="onClick"
tools:layout_editor_absoluteX="18dp"
tools:layout_editor_absoluteY="582dp" /> </androidx.constraintlayout.widget.ConstraintLayout>
</ScrollView>
[/CODE]
Technology news on Phys.org
Yes, it is possible to put radio buttons above an ImageView in a ScrollView. One solution could be to use a RelativeLayout instead of a ConstraintLayout, and then use the android:layout_above attribute to position the radio buttons above the ImageView. Another solution could be to use a LinearLayout and use the android:layout_weight attribute to adjust the height of the ImageView and the radio buttons. You could also try using a FrameLayout and using the android:layout_gravity attribute to position the views. Experiment with different layouts and attributes to find the best solution for your specific needs.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
