Can I replace a 4 ohm speaker with a 4 ohm power resistor?
Replacing a 4 ohm speaker with a 4 ohm power resistor is feasible, but typically unnecessary; simply not connecting the tweeter terminals is often a better option. Using a resistor across the tweeter terminals can work, with values around 3.9 to 4.7 ohms being acceptable. A passive filter will not significantly add resistance or rob power from the speaker, as losses are minimal. Adjusting tone controls on the amplifier is generally a simpler solution, although the specific amplifier in question lacks this feature. Ultimately, using a resistor or filter can be a workaround, but simpler alternatives may be more effective.
pkc111
TL;DR Summary
I have a single speaker powered by an off the shelf rechargeable boom-box. The speaker is 4 ohm 10W and I want to take the treble out completely as I am going to use it to drive a Ruben's tube. I was thinking of using a 2 way lowpass passive filter from Amazon inline before the speaker. I have read that they only work if there are 2 speakers connected, so would it work if I placed a 4 ohm power resistor across the tweeter speaker terminals and just used my speaker across the bass terminals?
Also would a passive filter add much resistance to the circuit and rob the speaker of power?
Here is the 2 way lowpass filter I was thinking of. I don't need 2 of these obviously but they seem to come as a pair.
https://www.amazon.com.au/dp/B07R613YSK/
Yes, but usually not needed.
You could just not connect the Tweeter terminals at all. Or even short them if really needed.
Much easier/cheaper to adjust the tone controls on the amplifier.
Cheers,
Tom
Replace the tweeter with an approximately 4 ohm resistor. It is not critical, 3R9 or 4R7 would work OK.
No. The losses in the filter are small.
Thank you so much!
I agree the tone adjustment on the amp would be easier.. but it doesn't have one. Its the Tribit Stormbox
https://www.tribit.com/products/Tribit-StormBox-Portable-Speaker-Black
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
