B Can I replace ##X_n = i## with ##A## to type less? Rules of math.
  • B
  • Thread starter Thread starter docnet
    Random variables
Substituting placeholders like A for specific equations such as X_n=i can simplify notation but risks oversimplification and loss of important information. While it may seem logically consistent if A retains all attributes of X_n=i, using arbitrary sets for A, B, and C can lead to incorrect conclusions, particularly in probability contexts. This practice is often frowned upon in academic settings, especially if it stems from laziness, as it complicates understanding and verification of the equations. It's generally better to maintain specific equations to preserve clarity and meaning. In formal logic and mathematics, using symbols to represent entire equations is acceptable, but care must be taken to ensure they convey the intended meaning.
docnet
TL;DR Summary
Am I allowed to use placeholders to represent equations?
When working with random variables, it is tempting to make substitutions with placeholders, by writing writing ##A## instead of ##X_n=i##, because it greatly simplifies the look. It seems that if ##A## has all of the attributes of the equation ##X_n=I##, then such substitutions should be allowed because it is not logically inconsistent.
For example, I might replace
##(X_{n+1}=j )\text{ with } A##
##(X_{n}=i)\text{ with } B##
and
##(X_{n-1}=k)\text{ with } C.##
Then I could write ##P(A|B,C)=P(A|B)## because ##\{X_n\}## is a Markov chain.
But, if ##A, B##, and ##C## were arbitrary sets, then the above equation would not be true in general. So is this very very lazy and frowned upon mistake that only first year undergraduates make? It seems like my professor became stern because I did this on the last assignment, maybe she was angry that I was so lazy?
Mathematics news on Phys.org
There's a saying: "Make things as simple as possible, but no simpler."
Replacing an equation that contains important information with a single letter seems to me to be oversimplification.
and
Doesn't seem like a good idea to me.
Or she might have been peeved that your simplification was one that discarded important information.
Replacing a given, specific, equation with a symbol is usually a bad idea. You can represent general concepts with symbols, especially in logic. You can sometimes represent sets and events in probability with a letter to represent the set. It's usually better to show specific equations exactly. If your motivation to do it is out of laziness, then there is no excuse. In you example, because you do not want to type the equations, I need to look back at what A, B, and C are to determine if your probability statement makes sense. If the definitions were not right above, it would be very annoying.
Likes Mark44 and docnet
If your symbols indicate the meaning of the equation/statement that would be much different from your A, B, C example, which conveys no meaning. I'm not sure if there is any real significance to the values of i, j, and k, in your example. If not, for a Markov process, you can say that ##S_k## indicates the state at step ##k## and ##P(S_{n+1} | S_n, S_{n-1}) = P(S_{n+1} | S_n)##.
So it is ill-advised to do. I will never do it again. It is so strange that I did that in the first place. I think I was feeling physical pain from having to sit on the keyboard and type, but I could not justify it afterwards because there is really no reason to take such a bad looking shortcut.
Out of curiosity, Is there a situation where something like it would make sense, representing logic statements with a single symbol?
Yes. It is often done in logic. And in general math, equations are often given numbers so that they can be referred to later in the text. But notice that you are not using A, B, and C, to represent equations. They are representing events, described using equations.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
