Can I reverse the PdV integral for work?
The discussion revolves around whether the work integral W = ∫PdV can be reversed to W = ∫V dP, given specific parameters of a thermodynamic problem. The user has values for pressures and volume but lacks total mass, final volume, and temperatures. They propose solving for volume as a function of pressure and integrating, but seek confirmation on the validity of this approach. The response indicates that reversing the integral is not straightforward and suggests using integration by parts instead. The conclusion emphasizes the need for careful consideration of the integration process in thermodynamic equations.
Hercuflea
I have a problem where I know P1, P2, V1, and molecular mass. I do not know total mass, final volume, temperature 1 or temperature 2, or the work. I also know that P = 40V^2 + 20
Can I reverse the W = ∫PdV equation into the form W = ∫V dP? Because I could just solve the equation for V = sqrt(P/40 - 1/2) and integrate that. Can I do this?
W = ∫PdV
Qdot - Wdot = mdot ((u2 + v^2/2 + gz2) - (u1 + v^2/2 +gz1))
no heat transfer, constant mass, no change in altitude, no velocity. The system is being compressed.
Hercuflea said:
Can I reverse the W = ∫PdV equation into the form W = ∫V dP? .
Not quite. Integration by parts: ##\int_a^by.dx + \int_{y(a)}^{y(b)}x.dy = [xy]_{x=a}^{x=b}##
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
