Can i use bernoulis inequality like this?
  • Thread starter Nerpilis
  • Tags
    Inequality
In summary, the conversation discusses the use of Bernoulli's inequality to find a limit. The person initially asks if they can use Bernoulli's inequality in a certain way, but it is pointed out that their use of the inequality is incorrect. The correct use of Bernoulli's inequality is then explained, and it is shown that it can be used to find the limit in question, which is greater than 2 and approaches the value of e.
Nerpilis
can I use bernoulis inequality like this for finding this limit?
[tex]\lim_{n\rightarrrow\infty}(1+\frac{1}{2n}) \geq \lim (1+2n(\frac{1}{2n})) \geq 2[/tex]
Well,first of all, you aren't using Bernoulli's inequality.
Bernoulli's inequality says that
[tex](1+x)^r\ge 1+rx[/tex]
as long as x and r are both larger than -1.
In this case, r= 1 so Bernoulli's inequality doesn't say anything.
In any case, isn't it obvious that, as [itex]x->\infty[/itex],
[tex]\frac{1}{2n}-> 0[/tex]?
And so
[frac]1+ \frac{1}{2n}\rightarrow 1[/tex].
Or did you mean
[tex]lim_{n\rightarrow\infty}\left(1+\frac{2n}\right)^{2n}[/tex]?
Yes, Bernoulli's inequality applies to this and shows that the limit is greater than 2. In fact, it should be clear that the limit is e which is certainly larger than 2!
your right i did have a typo i meant
[tex]\lim_{n\rightarrrow\infty}(1+\frac{1}{2n})^{2n} \geq \lim (1+2n(\frac{1}{2n})) \geq 2[/tex]
FAQ: Can i use bernoulis inequality like this?
Can I apply Bernoulli's inequality to any type of equation?
No, Bernoulli's inequality can only be applied to equations involving real numbers and exponents. It cannot be used for complex numbers or equations with variables.
How do I know if I can use Bernoulli's inequality for a specific problem?
You can use Bernoulli's inequality if the equation involves a variable raised to a power greater than or equal to one. It is also applicable for inequalities with a positive exponent.
Is Bernoulli's inequality only useful for solving mathematical problems?
No, Bernoulli's inequality has various applications in fields such as physics, engineering, and economics. It can be used to analyze and model various real-world phenomena.
What are the limitations of using Bernoulli's inequality?
Bernoulli's inequality is only applicable for equations with positive exponents. It also cannot be used for equations involving negative numbers or zero.
Can I use Bernoulli's inequality to prove other mathematical theorems?
Yes, Bernoulli's inequality can be used as a tool in proving other mathematical theorems and inequalities, such as the AM-GM inequality and the Cauchy-Schwarz inequality.
