Can I Use the Difference of Cubes Formula for Factoring 27 - (a - b)^3?
  • MHB
  • Thread starter mathdad
In summary, Factor 27 - (a - b)^3 is a way to calculate the difference of cubes when given two numbers, a and b.
mathdad
1,283
Factor 27 - (a - b)^3.
Can I apply the difference of cubes formula here?
If this is true, then in the formula a = 3 and b = (a - b).
Right?
Note: 27 became 3^3 leading to a = 3 in the difference of cubes formula.
Mathematics news on Phys.org
Right?
Yes.
Then in case of doubt you after factoring can multiply and see the result
You need to clarify your variables. "b = (a - b)" isn't right. Pick a variable name, say, p... Anything but that b on the LHS... Then you have p = a - b.
-Dan
-Dan
In the difference of cubes, let a = 3 and p = (a - b).
a^3-b^3 = (a-b)(a^2+ab+b^2)
a^3 - b^3 = (3 - p)(3^3 + 3p + p^2)
I must now simplify The RHS and then back-substitute for p.
Yes?
It might be more clear to state something like the following:
The difference of cubes formula states:
\(\displaystyle p^3-q^3=(p-q)\left(p^2+pq+q^2\right)\)
And so, given:
\(\displaystyle 3^3-(a-b)^3\)
If we let $p=3$ and $q=a-b$, we obtain:
\(\displaystyle 3^3-(a-b)^3=(3-(a-b))\left(3^2+3(a-b)+(a-b)^2)\right)\)
And so, given:
Great substitution!
FAQ: Can I Use the Difference of Cubes Formula for Factoring 27 - (a - b)^3?
Can I use the difference of cubes formula for factoring 27 - (a - b)^3?
Yes, the difference of cubes formula can be used to factor 27 - (a - b)^3. The formula is (x - y)(x^2 + xy + y^2) and in this case, x = 3 and y = (a - b).
What is the difference of cubes formula?
The difference of cubes formula is a mathematical expression used to factor the difference of two cubes. It is (x - y)(x^2 + xy + y^2), where x and y are the cube roots of the two terms being subtracted.
How do I know when to use the difference of cubes formula for factoring?
The difference of cubes formula is used when you have a difference of two cubes, meaning two terms being subtracted where one is a perfect cube and the other is the cube of a binomial. In this case, 27 is a perfect cube and (a - b) is the cube of a binomial.
Can the difference of cubes formula be used for factoring other types of expressions?
No, the difference of cubes formula can only be used for factoring expressions with a difference of two cubes. For other types of expressions, different factoring methods must be used.
Are there any special cases or exceptions when using the difference of cubes formula?
Yes, there are a few special cases when using the difference of cubes formula. If the expression being factored has a coefficient other than 1, it must be factored out first. Also, if the binomial being cubed has a negative sign, it must be factored out as -1. Lastly, if the expression has a common factor, it must be factored out before using the formula.
11K
