MHB Can inequality be proven with positive real numbers and fractions?
  • Thread starter Thread starter anemone
    Inequality
The discussion focuses on proving the inequality involving positive real numbers x, y, and z that satisfy the equation 1/x + 1/y + 1/z = 3. The goal is to demonstrate that 1/√(x^3 + 1) + 1/√(y^3 + 1) + 1/√(z^3 + 1) is less than or equal to 3/√2. Participants share their solutions and engage in problem-solving techniques. The conversation highlights the importance of mathematical proofs in understanding inequalities. Overall, the thread emphasizes collaborative problem-solving in mathematics.
anemone
MHB
POTW Director
For the positive real numbers $x,\,y$ and $z$ that satisfy $\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}=3$, prove that
$\dfrac{1}{\sqrt{x^3+1}}+\dfrac{1}{\sqrt{y^3+1}}+\dfrac{1}{\sqrt{z^3+1}}\le \dfrac{3}{\sqrt{2}}$.
Mathematics news on Phys.org
My solution:
Using cyclic symmetry, we find the extremum must occur for:
$$(x,y,z)=(1,1,1)$$
If we define:
$$f(x,y,z)=\frac{1}{\sqrt{x^3+1}}+\frac{1}{\sqrt{y^3+1}}+\frac{1}{\sqrt{z^3+1}}$$
then we obtain:
$$f(1,1,1)=\frac{3}{\sqrt{2}}$$
To determine the nature of the extremum, we pick another point on the constraint:
$$(x,y,z)=\left(2,\frac{4}{5},\frac{4}{5}\right)$$
And we find:
$$f\left(2,\frac{4}{5},\frac{4}{5}\right)=\frac{21+10\sqrt{105}}{63}<\frac{3}{\sqrt{2}}$$
Thus, the extremum is a maximum, and we may state:
$$f(x,y,z)\le\frac{3}{\sqrt{2}}$$
MarkFL said:
My solution:
$$(x,y,z)=(1,1,1)$$
If we define:
then we obtain:
And we find:
Good job, MarkFL! And thanks for participating!
My solution:
By AM-GM, we have $x^3+1\ge 2x\sqrt{x}$ so $\dfrac{1}{\sqrt{x^3+1}}\le\dfrac{1}{\sqrt{2}\sqrt{x}\sqrt[4]{x}}$. By the same token we also have $\dfrac{1}{\sqrt{y^3+1}}\le\dfrac{1}{\sqrt{2}\sqrt{y}\sqrt[4]{y}}$ and $\dfrac{1}{\sqrt{z^3+1}}\le\dfrac{1}{\sqrt{2}\sqrt{z}\sqrt[4]{z}}$.
Adding the three inequalities we get:
$\dfrac{1}{\sqrt{x^3+1}}+\dfrac{1}{\sqrt{y^3+1}}+\dfrac{1}{\sqrt{z^3+1}}\le\dfrac{1}{\sqrt{2}}\left(\dfrac{1}{\sqrt{x}\sqrt[4]{x}}+\dfrac{1}{\sqrt{y}\sqrt[4]{y}}+\dfrac{1}{\sqrt{z}\sqrt[4]{z}}\right)$
Note that the following can be obtained by Cauchy–Schwarz inequality:
$\dfrac{1}{\sqrt{x}}+\dfrac{1}{\sqrt{y}}+\dfrac{1}{\sqrt{z}}\le\sqrt{1+1+1}\sqrt{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}=\sqrt{3}\sqrt{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}$
$\dfrac{1}{\sqrt{x}\sqrt[4]{x}}+\dfrac{1}{\sqrt{y}\sqrt[4]{y}}+\dfrac{1}{\sqrt{z}\sqrt[4]{z}}\le\sqrt{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}\sqrt{\dfrac{1}{\sqrt{x}}+\dfrac{1}{\sqrt{y}}+\dfrac{1}{\sqrt{z}}}=\sqrt{3}\sqrt{\left(\sqrt{3}\sqrt{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}\right)}$
Putting these pieces together, and since we're told that $\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}=3$ we see that we have proved:
$\begin{align*}\dfrac{1}{\sqrt{x^3+1}}+\dfrac{1}{\sqrt{y^3+1}}+\dfrac{1}{\sqrt{z^3+1}}&\le\dfrac{1}{\sqrt{2}}\left(\dfrac{1}{\sqrt{x}\sqrt[4]{x}}+\dfrac{1}{\sqrt{y}\sqrt[4]{y}}+\dfrac{1}{\sqrt{z}\sqrt[4]{z}}\right)\\&\le \dfrac{1}{\sqrt{2}} \sqrt{3}\sqrt{\left(\sqrt{3}\sqrt{\dfrac{1}{x}+\dfrac{1}{y}+\dfrac{1}{z}}\right)}\\&\le \dfrac{3}{\sqrt{2}}\end{align*}$
anemone said:
Good job, MarkFL! And thanks for participating!...
You likely knew I would use cyclic symmetry just as surely as I knew you would use AM-GM. (Smirk)
LOL! That is very true!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
