Can Integer Equations Reveal Perfect Square Patterns?
  • MHB
  • Thread starter anemone
In summary, to prove that a pattern in an equation is a perfect square, you can simplify the equation, identify perfect square numbers, rewrite the equation using their square roots, and check for equality. Integers are whole numbers that can be positive, negative, or zero. An example of a perfect square pattern in an equation with integers is x^2 + 6x + 9 = (x + 3)^2. Proving perfect square patterns can be useful in math for simplifying expressions, factoring polynomials, and solving quadratic equations. Some shortcuts for identifying perfect square patterns include looking for patterns in coefficients and checking for factoring into the square of a binomial.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Suppose that the positive integers $x, y$ satisfy $2x^2+x=3y^2+y$. Show that $x-y, 2x+2y+1, 3x+3y+1$ are all perfect squares.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution!(Cool)
1. kaliprasad
2. castor28
3. Opalg
Solution from Opalg:
If $2x^2+x = 3y^2+y$ then $2(x^2-y^2) + (x-y) = y^2$ and so $(2x+2y+1)(x-y) = y^2$.
Now suppose that $p$ is a prime divisor of $x-y$. Then $p$ divides $y^2$ and hence $p$ divides $y$. Thus $p$ divides $2x+2y$, so it does not divide $2x+2y+1$. But $p$ occurs to an even power in the prime factorisation of $y^2$. Since it does not occur as a factor of $2x+2y+1$, it must occur to an even power in the prime factorisation of $x-y$. As this is true for every prime factor of $x-y$, it follows that $x-y$ is a square, say $x-y = z^2$. But then $z^2$ is a factor of $y^2$, and $2x+2y+1 = \frac{y^2}{z^2} = \left(\frac yz\right)^2$, so that $2x+2y+1$ is a square.
If we write the equation $2x^2+x = 3y^2+y$ as $3(x^2-y^2) + (x-y) = x^2$, then $(3x+3y+1)(x-y) = x^2$, and the same argument as before shows that $3x+3y+1$ is a square.
FAQ: Can Integer Equations Reveal Perfect Square Patterns?
How do you determine if an equation is a perfect square with integers?
To determine if an equation is a perfect square with integers, you can take the square root of both sides of the equation. If the square root is an integer, then the equation is a perfect square with integers.
Can an equation be a perfect square with non-integer coefficients?
No, an equation cannot be a perfect square with non-integer coefficients. In order for an equation to be a perfect square, the coefficients must be integers.
What is the difference between a perfect square and a square number?
A perfect square is an integer that can be expressed as the product of two equal integers. A square number is any number that can be expressed as the product of two equal numbers, which can be integers or non-integers.
Can a negative number be a perfect square?
Yes, a negative number can be a perfect square. For example, -25 is a perfect square because it can be expressed as (-5)^2.
How can proving perfect square patterns in equations with integers be useful in real life?
Proving perfect square patterns in equations with integers can be useful in various fields such as finance, engineering, and cryptography. In finance, it can be used to calculate interest rates and determine the value of investments. In engineering, it can be used to solve problems related to area and volume. In cryptography, it can be used to create secure codes and protect sensitive information.
