Can Jib Cranes Survive High Winds?
  • Thread starter Greg Bernhardt
  • Tags
    Crane Wind
In summary, the conversation discusses the presence of a jib crane outside the speaker's window, with concerns about its movements in high winds and how it is controlled. The speaker mentions researching and discovering that many cranes have a "weathervane" mode to handle high winds, and provides a video example of one in action. It is also mentioned that the motors of the crane work as generators to charge batteries. The standard procedure for high winds is to let the crane weather vane rather than risk collapse.
10,322
Across the street from my apartment there is a building under construction and a large jib crane is right outside my window. Today we have 20-30mph winds. All construction workers have gone home for the day. I see that the crane is rotating back and forth. It's very unnerving, but as I read perfectly normal and necessary. I just wonder how it knows where to point and what is controlling it. For a few minutes it was rotating quite a bit back and forth. However now it looks to have stopped yet the winds are still blowing quite hard. Is it just moving with the wind or is there some sort of motor and computer system to tell it where to point? What happens if a severe storm hits? Can the crane survive 60-70-80mph gusts?
I just did a quick Google search, and apparently many are set into "weathervane" mode in this situation
This one seems to go into windmill mode:
https://www.youtube.com/watch?v=aPNGbv4EhL4
The motors work as generators and charge the batteries!
Standard procedure is to let them weather vane. The the other option is to let them collapse due to side loading. They will tolerate a great deal of wind this way.
FAQ: Can Jib Cranes Survive High Winds?
1. How does a jib crane move with the wind?
A jib crane moves with the wind due to its lightweight and flexible design. The crane's structure allows it to sway and adjust its position according to the direction and strength of the wind.
2. Is it safe to operate a jib crane in windy conditions?
Yes, jib cranes are designed to withstand windy conditions. However, it is important to follow safety precautions and guidelines, such as reducing the crane's load capacity and securing the crane to the ground or structure.
3. Can the wind affect the accuracy of a jib crane's movements?
Yes, strong winds can affect the accuracy of a jib crane's movements. It is important to consider wind speeds and direction when operating a jib crane to ensure precise and safe movements.
4. How does wind speed and direction affect the operation of a jib crane?
Wind speed and direction can affect the operation of a jib crane by causing the crane to sway or move unexpectedly. It is important to monitor wind conditions and adjust the crane's movements accordingly to maintain safety and accuracy.
5. Are there any special precautions to take when using a jib crane in windy conditions?
Yes, there are several precautions to take when using a jib crane in windy conditions. These include reducing the crane's load capacity, securing the crane to the ground or structure, and monitoring wind conditions to adjust the crane's movements. It is also important to follow all safety guidelines and protocols set by the manufacturer.
