Can Kinematics and Energy Conservation Solve the Egg Drop Problem?
In summary, the problem involves an egg being dropped from a third-floor window and landing on a foam-rubber pad without breaking. Using kinematics, the pad is compressed by 4.79cm. Alternatively, conservation of energy can be used to find the egg's velocity as it hits the pad. The egg's mass is not needed for this problem.
claudiairiond
An egg is dropped from a third-floor window and lands on a foam-rubber pad without breaking. If a 56.0g egg falls 12.0m from rest and the 5.00cm thick foam pad stops it in 6.25ms, by how much is the pad compressed? Assume constant upward acceleration as the egg compresses the foam-rubber pad. (Hing: Assume that the potential energy that the egg gains while the pad is being compressed is negligible.)
Vf2=Vi2+2a∆y
∆y=((vi+vf)/2)*t
F=ma
KEi + PEi= KEf+PEf+W
Separated the problem into two parts: first part when the egg travels through the air until it reaches the pad, then, when the egg hits the pad and compresses it.
Part 1:
Vf= 15.3 m/s
Therefore the acceleration of the egg going into the pad would be
a= (0m/s-15.3m)/.00625s
a= -2400m/s2
THEN
∆y= ((15m/s-0m/s)/2)*.00625s
∆y=.046875m
The pad is compressed 4.79cm!
BUT, I never took into account that the egg is 56 g!
How can I approach this using energy?!
Given the way the problem was stated, you don't really need to.
You can use conservation of energy as an alternate way to find egg's velocity as it hits the pad. The way you approached the problem using kinematics also works. But you can use conservation of energy to check you work if you wanted to.
o What is the gravitational potential energy of 56.0g egg at a height of 12 m?
o What's the formula for an object's kinetic energy as function of velocity, v?
o Invoking conservation of energy, solve for v.
(That gets you the velocity of the egg at the moment it hits the pad. You can't use conservation of energy after the egg hits the pad though [some of the energy is lost to heat].)
(You might want to go back and check your significant digits in your original attempt. You might have made a precision mistake or two.)
FAQ: Can Kinematics and Energy Conservation Solve the Egg Drop Problem?
What is the energy problem?
The energy problem refers to the challenge of meeting the growing demand for energy while also reducing the negative impact on the environment and mitigating the effects of climate change.
How can kinematics help solve the energy problem?
Kinematics, the study of motion, can help in solving the energy problem by providing insights into the efficiency and performance of energy systems. By analyzing the motion and forces involved in energy production and consumption, we can identify ways to improve efficiency and reduce waste.
What role does renewable energy play in solving the energy problem?
Renewable energy, such as solar, wind, and hydropower, plays a crucial role in solving the energy problem. These sources of energy are sustainable and have a much lower impact on the environment compared to fossil fuels. By increasing the use of renewable energy, we can reduce our reliance on non-renewable resources and decrease greenhouse gas emissions.
How can we use kinematics to optimize energy production?
Kinematics can help us optimize energy production by analyzing the motion and forces involved in energy systems. By understanding the efficiency and performance of these systems, we can identify areas for improvement and make adjustments to increase energy production and reduce waste.
What are some potential challenges in using kinematics to solve the energy problem?
One potential challenge in using kinematics to solve the energy problem is the complexity of energy systems. There are many variables and factors to consider, and it may be difficult to accurately model and predict the behavior of these systems. Additionally, implementing changes based on kinematics analysis may require significant investments and time for research and development.
