Can light produce weak gravity waves?
In summary, the author of the article suggests that light can produce minute gravitational waves, and that the energy of the waves would be dissipated on the order of cosmological redshifts.
dan_b_
I have read online that light can produce a weak gravitational field (for example antiparallel beams should, in principle, attract weakly). This made me wonder if light can produce minute gravitational waves. Even if the waves were extremely weak (no disregarding of those high order terms in the applicable equation, whatever equation that may be), could the gravitational waves dissipate energy (on the order that is expected for cosmological redshifts) when light travels across cosmological distances ? I was thinking about the debunked tired-light hypothesis regarding the cosmological redshift, and I wondered if anyone has considered a mechanism whereby gravity waves dissipate energy.
A graviton would travel at the speed of light too. So a photon could not emit a graviton ahead of it. Nor could it emit a graviton to right angles to the direction of a photon, for then it would be going faster than the speed of light, having a velocity c in the direction of the photon plus a velocity c to right angles. These two velocities would add to produce a speed faster than the speed of light and so can not exist. Also a photon could not emit a graviton in the direction opposite a photon. For then that graviton would be at rest, being emitted with -c from a photon traveling at +c. And a graviton cannot exist at rest. So I would have to think that a photon does not produce any gravitational effects.
The OP is correct that per GR, anti parallel beams attract. Further, a light beam attracts a particle of matter. Finally, the OP's guess that light can produce GW is correct. The following:
"When electromagnetic waves collide, it appears that gravitational
waves are always generated by the collision. These may be impulsive
waves that occur along the boundaries of region IV only, or they may
appear throughout the interaction region. However, they must always
appear."
is a conclusion from
https://archive.org/details/flooved2797
However, there is no support for any 'tired light' concept, because an EM wave by itself, produces no GW.
appear." is a conclusion from https://archive.org/details/flooved2797.
I'm not sure how that is consistent with photons passing through each other unaffected. If colliding photons produce gravitational waves, then it seems that the energy of the EM waves (photons) would be decreased by the energy of the gravitational waves that are emitted.
Well, this is classical GR. However, in QFT, photons CAN interact with each other via multi-loop interactions (the probability is just vanishingly small). For example, there is computable (exceedingly small) probability that colliding high energy photons can produce positron-electron pair without mediation of another charged particle. Thus, in a quantum gravity theory, it would seem expected that there is a chance of graviton production, and that the photon energy after interaction is reduced.
Pe
Perhaps should you read: "One loop photon-graviton mixing in an em field; part2 arxiv:0710.5572v1, "As has been recognized many years ago... the quantized Einstein-Maxwell theory predicts the process of photon-graviton conversion in an em field..."
Related to Can light produce weak gravity waves?
1. Can light produce weak gravity waves?
There is currently no conclusive evidence that light can produce weak gravity waves. While there have been theories and experiments attempting to prove this concept, it is still a topic of ongoing research and debate among scientists.
2. What are gravity waves?
Gravity waves are ripples in the fabric of space-time that are caused by the acceleration of massive objects. They were first predicted by Albert Einstein's theory of general relativity and have since been detected by gravitational wave observatories.
3. How are gravity waves different from light?
Gravity waves and light are fundamentally different phenomena. Light is a type of electromagnetic radiation that travels at the speed of light and interacts with matter, while gravity waves are caused by the warping of space-time and do not interact with matter.
4. Can gravity waves travel faster than light?
No, according to Einstein's theory of relativity, nothing can travel faster than the speed of light in a vacuum. This includes gravity waves, which also travel at the speed of light.
5. What are the potential applications of gravity waves?
Gravity waves have the potential to provide valuable insights into the workings of the universe, such as the behavior of black holes and the formation of galaxies. They could also potentially be used for future technologies, such as improved methods of communication and navigation in space.
  • Beyond the Standard Models
  • Astronomy and Astrophysics
