Can Logarithmic Functions Be Expressed as Infinite Series?
In summary, the conversation discussed a proof involving a logarithmic equation that did not converge in the given interval. The expert suggested using logarithm rules, looking for patterns in the infinite sum, and revisiting the integral approach to potentially find a solution.
MupptMath
Hi,
I'm stuck on the following proof:
\(\displaystyle \log[3] = \frac 1{729} \sum_{k=0}^\infty \frac 1{729^k} \left[\frac{729}{6k+1}+\frac{81}{6k+2}+\frac{81}{6k+3}+\frac 9{6k+4}+\frac 9{6k+5}+\frac 1{6k+6}\right]\)
Manipulating and converting summands to integrals of the form $x^{-(6k+n)}$ over {x,0,3} seems to provide a nice reduction but does not converge in that interval and am uncertain how to proceed. Manipulating indices and summands to reduce to certain series doesn't quite work. Seems so close, but so far.
Thanks.
Hi there,
Thank you for reaching out for help with this proof. After looking at the equation and trying out a few manipulations myself, I have a few suggestions that may help you make progress.
Firstly, when dealing with logarithms, it can be helpful to use the logarithm rules to manipulate the equation. In this case, you can use the rule $\log_a(bc) = \log_a(b) + \log_a(c)$ to split the logarithm into multiple terms. This may help simplify the equation and make it easier to work with.
Additionally, when dealing with infinite sums, it can be helpful to look for patterns or common terms that can be factored out. In this case, you may notice that the terms inside the square brackets have a common factor of 9. You can use this to simplify the equation and possibly find a way to convert it into a convergent series.
Lastly, I would suggest revisiting the integral approach you mentioned. Sometimes, integrating over a different interval or using a different variable can help with convergence issues.
I hope these suggestions are helpful and that you are able to make progress on your proof. Good luck!
FAQ: Can Logarithmic Functions Be Expressed as Infinite Series?
What is a "Log (3) Equivalence Proof"?
A "Log (3) Equivalence Proof" is a mathematical proof used to show that two expressions or equations are equivalent in terms of their logarithmic values. It involves using properties of logarithms, such as the product, quotient, and power rules, to manipulate the expressions and show that they are equal.
Why is a "Log (3) Equivalence Proof" important?
A "Log (3) Equivalence Proof" is important because it allows us to simplify and manipulate logarithmic expressions, making them easier to work with and solve. It also helps us to understand the relationship between different logarithmic expressions and how they can be transformed into one another.
What are the steps involved in a "Log (3) Equivalence Proof"?
The steps involved in a "Log (3) Equivalence Proof" include identifying the properties of logarithms that can be used, manipulating the expressions using those properties, and showing that the two expressions are equal. This often involves algebraic manipulation and cancelling out terms on both sides of the equation.
When would you use a "Log (3) Equivalence Proof"?
A "Log (3) Equivalence Proof" can be used whenever you need to simplify or transform logarithmic expressions. This can be useful in solving equations, evaluating limits, and in other mathematical calculations involving logarithms.
Are there any common mistakes to watch out for when doing a "Log (3) Equivalence Proof"?
Some common mistakes to watch out for when doing a "Log (3) Equivalence Proof" include forgetting to apply the correct properties of logarithms, making errors in algebraic manipulation, and not simplifying the expressions enough to show equivalence. It is important to double check your work and make sure that all steps are clearly shown and correct.
