Anamitra
- 621
PRELUDE:
We consider two points A and X . A light ray flashes across an infinitesimally small spatial interval dL at X.
Local time interval(physical) measured by observer at X:Sqrt[g(X:tt)]dt
Time interval(physical) measured by observer at A = Sqrt[g(A:tt)]dt Local speed of light at measured at X= dL/[g(X:tt)dt] = c .Speed measured from A ie,
C[non-local]= dL/[g(A:tt)] = Sqrt[g(X:tt)/ [g(A:tt]] * c . ------------ (1)
The above value in general is different from c. It might exceed the value of c ,the local speed limit.
We again consider two points A and X . A particle moves across an infinitesimally small spatial interval dL at X.
Local time interval(physical) measured by observer at X: Sqrt[g(X:tt)]dt .
Time interval(physical) measured by observer at A =Sqrt[ g(A:tt)]dt
Local speed of particle measured at X:v= dL/Sqrt[g(X:tt)dt]
V[non-local]= dL/Sqrt[g(A:tt)] =Sqrt[ g(X:tt)/ [g(A:tt]] * v -------------------- (2)
The above value might exceed the local speed limit of c depending on the ratio g(X:tt)/[g(A:tt)] [Chances are greater for fast moving particles like neurtinos]
But the particle cannot exceed the NON-LOCAL speed barrier since ,locally v<c. We have from relations(1) and (2):
V[Non-local]< C[non-Local]
The particle never achieves a superluminal rate in these considerations. It simply crosses[rather reserves the right to cross] the local speed barrier “c” when non-local measurements are being made. Important Points to Observe:
1. This procedure DOES NOT violate Special Relativity in the local
context
2. The Non-local speed barrier is not broken[the local speed barrier is maintained in local experiments]
3. The procedure/formulation accepts Non-Local speeds/velocities in GR
[The fact that velocities of satellites constrained in orbits have been accurately measured/estimated demonstrates the existence of non- local velocities in curved spacetime. It is important to take note of
the fact that the spacetime curvature around the Earth is strong enough to maintain satellites[natural and artificial] in their orbits. This is the work of space-time curvature and not something known as the “Force of Gravity”[which is classically known to produce centripetal acceleration]. A person falling out of a roof is seriously in trouble----the acceleration caused is due to the Geometry of space. It is not due to something called the “force” of Gravity! ] . The Geometry of Space causes rivers to flow[provides hydroelectric power], causes the accelerated downward motion of landslides--- the list is quite long.
[Incidentally the experiment with the OPERA neutrinos was a terrestrial one]
SAMPLE CALCULATIONS
Length of path traversed by the OPERA neutrinos: 732km=732000m
Local time interval for the neutrino as it passes under the ground:
dT(L)=Sqrt[1- 2GM’/(c^2r)]dt
M’ is the Mass is the gravitating mass involved at the particular instant concerned, when the neutrino is moving through the earth.
Local Speed of neutrino=v=dL/ [Sqrt[1- 2GM’/(c^2R)]dt]
Non-Local time interval considered from the observation stations:
dT(NL)=Sqrt[1-2GM/(c^2r)]dt
Non-Local Speed, ie, observed speed=dL/ Sqrt[1-2GM/(c^2r)]dt
V[non-Local]=Sqrt[1- 2GM’/(c^2R)]/Sqrt Sqrt[1-2GM/(c^2r)]*v
Time taken[Observed time]=Integral[Sqrt[1- 2GM/(c^2R)]/Sqrt Sqrt[1-2GM’/(c^2r)]*(1/v)dL
--------------- (3)
The integral is to be computed between the endpoints of the path
Now,
M=4/3 (pi*R^3)*pho
M’=4/3(pi*r^3)*rho
M’/M=r^3/R^3
M’=(r^3/R^3 )*M
M[Mass of Earth]=5.98*10^24 kg; rho=mean density of the earth.
R=6400km=6400*1000m
Length “a“ be the length of the perpendicular from the center of the Earth to the chord ,which is the path of the neutrino.
Substitution:
Cos(x)=a/r
X:angle in radians
L=a tan(x)
L: distance from the center of the chord[732 km route] to an arbitrary point on the chord.
dL=a sec^2(x)dx=[a/(Cos(x))^2]dx
Integral(3)=Time[observed]=Sqrt{(1-GM/(c^2aCos(x)}/{1-GMa^2Cos^(x)/(c^2a^3)}(1/v)dL
Integral=integration[Sqrt{(1-GM/(c^2aCos(x)}/{1-GMa^2Cos^(x)/(c^2a^3)}(1/v)[a/(Cos(x))^2]dx ------------------ (4)
The limits of integration are the angles[in radians] between the end points of the path
The relation:
r=a/Cos(x) is important
r is a coordinate value so a should also be a coordinate value
The physical value corresponding to “a” = Sqrt[(6400*1000)^2 – (732/2 * 1000)^2]=6389526.117m
I am using the physical value in place of the coordinate value as an approximation
The limits of integration are from - ArcCos(a/R) to +ArcCos(a/R) : -0.0572187 to +0.0572187 radians
The integral works out[by numerical methods] to: 730403.299/v
Let us take v=0.997845c
=0.997845*3*10^8 m/s
Observed time: 730403.299/ [0.997845*3*10^8] seconds
Expected time for a light ray:732000/[3*10^8] seconds
Difference=
732000/[3*10^8]-730403.299/[.997845*3*10^8]
=6.427*10^(-8) Seconds.
=64 nano- seconds earlier
If the neutrinos travel with the speed “c” they would be reaching even earlier.
All this should hold with the assumption that the Earth is a homogeneous body
We have also taken the physical values of a and R
COORDINATE VALUES
Solving the equation:
R=Sqrt[r^2 – 2mr] + 2m ln[Sqrt(r)-Sqrt(r-2m)]+C
with R=6400000m
Link for the equation: https://www.physicsforums.com/showpost.php?p=3458428&postcount=126
We have R=6399924.39 m
Coordinate value of “a” may be determined by using the following relation[from similar triangles]
a/732000 = 6399924.39/6400000
The value of “a” works out to:6389455m
The angles (+/-)ArcCos(a/R) remain the same as before as expected[from similar triangles]
One may apply these values
Conclusion remains the same: The neutrinos can reach earlier than a signal traveling at the speed “c”
But these neutrinos are not super luminal. They always lag behind the Non local speed barrier for non-local observations. For local observations they are behind the local barrier.
context
SAMPLE CALCULATIONS
--------------- (3)
Now,
M=4/3 (pi*R^3)*pho
M’=4/3(pi*r^3)*rho
M’/M=r^3/R^3
M’=(r^3/R^3 )*M
R=6400km=6400*1000m
Substitution:
Cos(x)=a/r
X:angle in radians
L=a tan(x)
The relation:
Difference=
COORDINATE VALUES
with R=6400000m
