Can neutron stars lose energy?
In summary: Since the neutron star's magnetic field is so strong, it creates a lot of interesting EM radiation.The interior of a neutron star is composed mostly of degenerate neutrons which one would indeed expect to exchange energy via collisions instead of radiation. However, the surface is composed of more ordinary matter (still highly compressed) with electrons and nuclei, and there's nothing preventing these electrons from being bumped up to a higher energy level and then radiating while relaxing to a lower level.The original question appears to have been motivated by the concept of electron degeneracy, which might be applicable to limited regions of a neutron star but is more relevant to white dwarfs. There appears to be an assumption that because the lowest
magneticanomaly
TL;DR Summary
Since electromagnetic radiation is emitted as electrons decay from higher to lower states of excitation, I would assume that neutron stars cannot lose energy by blackbody radiation
Since electromagnetic radiation is emitted as electrons decay from higher to lower states of excitation, I would assume that neutron stars cannot lose energy by blackbody radiation. That would leave tidal drag and evaporation as the only ways a neutron star can lose energy...True?
Astronomy news on Phys.org
...and the massive beams of EMR they emit from their poles, by which they were discovered and named 'pulsars'.
How exactly does a mass of neutrons emit EMR? I thought this emission was from compression of non-degenerate matter as it falls into the neutron star.
The neutron star is rotating very rapidly and still has its magnetic field, which because of the small radius is very strong. This leads to all sorts of exciting electromagnetic effects.
@DaveC426913 mentioned "pulsars"; the wikipedia article is pretty good.
Likes Nik_2213 and Dragrath
Likes Dragrath
The original question appears to have been motivated by the concept of electron degeneracy, which might be applicable to limited regions of a neutron star but is more relevant to white dwarfs. There appears to be an assumption that because the lowest energy levels are all occupied, electrons can't radiate by moving to a lower energy level. However, there are many higher levels of varying energies, and an electron could radiate by moving from a "high" to a "medium" energy level, even if it can't go all the way down to the lowest energy. Thus electron degeneracy is not a barrier to blackbody radiation.
Likes magneticanomaly and Dragrath
Thanks, Barakn! Of course the pressure required to collapse ordinary matter will not exist near the surface of a "neutron" star, so ordinary blackbody radiation will be emitted from the surface. I feel silly not to have realized that!
Neutron stars can lose a lot of energy by emitting neutrinos. This is supposed to be the way recent formed neutron stars cool quickly.
The small surface area compared to the huge mass makes blackbody radiation not very efficient and only seems to become the dominant way of cooling after temperature dropped a lot.
Neutron stars the part about decline and fall of a neutron star describes these processes in more detail.
Summary:: Since electromagnetic radiation is emitted as electrons decay from higher to lower states of excitation, I would assume that neutron stars cannot lose energy by blackbody radiation
Note that this is not how solids, liquids, or even gases at low temperature (non glowing) emit radiation.
The photons will be produced by exciatation of a collection of atoms. Lattice vibrations, or molecule rotation/vibration, or collisions..
Likes russ_watters
IIRC, radio-astronomers routinely monitor 'young' neutron stars as they spin-down during their pulsar phase. Usually smoothly, but may have 'timing jumps' due 'star quakes'...
Likes Dragrath
Willem2, your comment on different modes of photon creation is appreciated. Keep in mind, though, that the surface temps of young neutron stars are often modeled as being a million Kelvin, and even older ones with surface temperatures close to our sun, so they don't qualify as "low temperature." Their quasi-blackbody spectrum is predominantly in the soft x-ray and ultraviolet range.
Likes Dragrath
Related to Can neutron stars lose energy?
1. What is a neutron star?
A neutron star is a type of compact star that is created when a massive star undergoes a supernova explosion. It is composed almost entirely of neutrons, which are subatomic particles that have no electrical charge.
2. How do neutron stars lose energy?
Neutron stars can lose energy through a process called "cooling." This occurs as the star's internal heat is radiated away into space over time. Neutron stars can also lose energy through gravitational radiation, which is the release of energy as the star's intense gravitational field changes.
3. Can a neutron star lose all of its energy?
No, it is not possible for a neutron star to lose all of its energy. As long as the star has a non-zero temperature, it will continue to radiate heat and lose energy. However, it is possible for a neutron star to lose enough energy to become a black hole.
4. How long does it take for a neutron star to lose energy?
The rate at which a neutron star loses energy can vary depending on its age, mass, and other factors. Generally, neutron stars cool down and lose energy over millions to billions of years.
5. What happens when a neutron star loses energy?
As a neutron star loses energy, it will gradually become cooler and dimmer. This can affect its physical properties, such as its size and magnetic field strength. In some cases, a neutron star may also undergo a phase transition and transform into a different type of object, such as a quark star.
  • Astronomy and Astrophysics
