fahraynk
- 186
- 6
I have a system of equations, and one of them is this : ##\int(1-U(y))Dy - H*\int(U(y)-U(y)^2)dy=0##
Can Newtons method work if I approximate this integral to be ##\sum_y(1-U(y))-H\sum(U(y)-U(y)^2)=0##
y is a set integers in range ##[1,1000]##
I have Newtons method working for this same system without this equation, but I am trying to solve for a new variable (a), so I added this equation and changed (a) from a constant to a new variable, but Newtons method no longer converges.
Could this be because I am using rectangle left rule to approximate the integral, and maybe rectangle left has too much error for Newtons method to work?
The other thing I can try is to take the derivative of both sides giving this equation ##1-U(y)-H(U(y)-U(y)^2=0##
The only problem with this is I would have to add this equation to every point on a grid, meaning it would be 1000 new equations for 1000 grid points instead of 1 equation. I would have to rewrite the whole algorithm, so I would rather use rectangle left rule if possible because it is much less coding.
Anyway, yeah, will Newtons method work with rectangle left rule like this?
