Can Nonlinear Second Order ODEs Be Solved Using Bernoulli Equations?
  • MHB
  • Thread starter Chris L T521
In summary, a nonlinear second order ODE is a mathematical equation that involves a function, its derivatives, and possibly the independent variable in a nonlinear way. It is important to solve these equations because they can be used to model many physical, chemical, and biological systems. There are various methods for solving nonlinear second order ODEs, and it is important to check the correctness of your solution by plugging it back into the original equation or graphing it. Some general tips for solving these equations include simplifying the equation, looking for special forms, and breaking it into smaller parts. It is also important to carefully check your work and ensure mathematical validity.
Chris L T521
MHB
915
We've finally made it to triple digits for the Problem of the Week on MHB! (Party)
Thanks again for your support and participation for almost two years now! We wouldn't have made it this far without you! (Bow)
Thanks again to those who participated in last week's POTW! Here's this week's problem (courtesy of MarkFL)!
Problem: Solve the nonlinear second order ODE $yy^{\prime\prime}=y^3+(y^{\prime})^2$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
For this POTW, I'm going to be lenient with grading it; the problem in its own right was challenging. However, there were a couple different approaches and several solutions were in terms of other (correct) functions not found in Mark's suggested solution. After reading through each submission, I've decided that the solutions provided by Ackbach, chisigma, Opalg, Pranav, and Sudharaka are "correct enough" for this problem.
You can find Mark's solution to this problem in all its detail below.
[sp]First, we may make the following substitution:
$\displaystyle u=\frac{dy}{dx}\implies \frac{d^2y}{dx^2}=\frac{du}{dx}=\frac{du}{dy}\frac{dy}{dx}=u\frac{du}{dy}$
and so the given ODE becomes the following system:
$\displaystyle \frac{dy}{dx}=u$
$\displaystyle uy\frac{du}{dy}=y^3+u^2$
The second of these equations may be written as:
$\displaystyle \frac{du}{dy}-\frac{1}{y}u=y^2u^{-1}$ where $u\ne0,\,y\ne0$.
This is a Bernoulli equation, and so mutiplying through by $2u$, we obtain:
$\displaystyle 2u\frac{du}{dy}-\frac{2}{y}u^2=2y^2$
This can also be written as:
$\displaystyle \frac{d}{dy}\left(u^2 \right)-\frac{2}{y}u^2=2y^2$
And this is an equation linear in $u^2$. Thus, we calculate the integrating factor:
$\displaystyle \mu(y)=e^{-2\int\frac{1}{y}\,dy}=y^{-2}$
Hence, the ODE then becomes:
$\displaystyle y^{-2}\frac{d}{dy}\left(u^2 \right)-\frac{2}{y^3}u^2=2$
Recognizing that the left side is the product of a differentiation, we may now write:
$\displaystyle \frac{d}{dy}\left(\frac{u^2}{y^2} \right)=2$
Integrating with respect to $y$, we obtain:
$\displaystyle \int\,d\left(\frac{u^2}{y^2} \right)=2\int\,dy$
$\displaystyle \frac{u^2}{y^2}=2y+c_1$
Thus, we have:
$\displaystyle u=\pm y\sqrt{2y+c_1}$ where $2y+c_1>0$
Now, substituting for $u$ in the first equation of the system we obtained above, we obtain:
$\displaystyle \frac{dy}{dx}=\pm y\sqrt{2y+c_1}$
Separation of variables and integrating gives us:
$\displaystyle \int\frac{1}{y\sqrt{2y+c_1}}\,dy=\pm \int\,dx$
For the integral on the left, it would help for us to develop a formula for:
$\displaystyle \int\frac{1}{w\sqrt{aw+b}}\,dw$
We have three cases to consider:
i) $0<b$
We may rewrite the integrand as follows:
$\displaystyle \frac{1}{w\sqrt{aw+b}}=\frac{1}{w\sqrt{aw+b}}\cdot\frac{\sqrt{aw+b}-\sqrt{b}}{\sqrt{aw+b}-\sqrt{b}}=\frac{1}{\sqrt{b}}\cdot\frac{1}{\sqrt{aw+b}-\sqrt{b}}\cdot\frac{aw-\left(aw+b-\sqrt{b(aw+b)} \right)}{w\sqrt{aw+b}}=$
$\displaystyle \frac{2}{\sqrt{b}}\cdot\frac{\sqrt{w}}{\sqrt{aw+b}-\sqrt{b}}\cdot\frac{\sqrt{w}\dfrac{a}{2\sqrt{aw+b}}-\left(\sqrt{aw+b}-\sqrt{b} \right)\dfrac{1}{2\sqrt{w}}}{w}=$
$\displaystyle \frac{2}{\sqrt{b}}\left(\frac{\sqrt{aw+b}-\sqrt{b}}{\sqrt{w}} \right)^{-1}\frac{d}{dw}\left(\frac{\sqrt{aw+b}-\sqrt{b}}{\sqrt{w}} \right)$
Hence, for this case we have:
$\displaystyle \int\frac{1}{w\sqrt{aw+b}}\,dw=\frac{2}{\sqrt{b}} \ln\left|\frac{\sqrt{aw+b}-\sqrt{b}}{\sqrt{w}} \right|+C$
ii) $b<0$
$\displaystyle \frac{1}{w\sqrt{aw+b}}=a\frac{1}{aw+b-b}\cdot\frac{1}{\sqrt{aw+b}}=\frac{2}{\sqrt{-b}}\cdot\frac{1}{\dfrac{aw+b}{-b}+1}\cdot\frac{1}{\sqrt{-b}}\cdot\frac{a}{2\sqrt{aw+b}}=$
$\displaystyle \frac{d}{dw}\left(\frac{2}{\sqrt{-b}}\tan^{-1}\left(\sqrt{\frac{aw+b}{-b}} \right) \right)$
$\displaystyle \int\frac{1}{w\sqrt{aw+b}}\,dw=\frac{2}{\sqrt{-b}}\tan^{-1}\left(\sqrt{\frac{aw+b}{-b}} \right)+C$
iii) $b=0$
$\displaystyle \int\frac{1}{w\sqrt{aw}}\,dw=\frac{1}{\sqrt{a}} \int w^{-\frac{3}{2}}\,dw=\frac{1}{\sqrt{a}}\left(-2w^{-\frac{1}{2}} \right)+C=-\frac{2}{\sqrt{aw}}+C$
And so using these results, we find the solution to the ODE given for the following cases:
i) $0<c_1$
$\displaystyle \frac{2}{\sqrt{c_1}}\ln\left|\frac{\sqrt{2y+c_1}-\sqrt{c_1}}{\sqrt{y}} \right|=\pm x+c_2$
ii) $c_1<0$
$\displaystyle \frac{2}{\sqrt{-c_1}}\tan^{-1}\left(\sqrt{\frac{2y+c_1}{-c_1}} \right)=\pm x+c_2$
iii) $c_1=0$
$\displaystyle \mp\frac{2}{\sqrt{y}}+c_2=\sqrt{2}x\implies y=\frac{4}{\left(x-c_2 \right)^2}$
Note: The function $y\equiv0$ (trivial solution) which we discarded in order to obtain the above solutions also satisfies the given ODE. It is a particular solution not obtainable from the three cases given. [/sp]
FAQ: Can Nonlinear Second Order ODEs Be Solved Using Bernoulli Equations?
What is a nonlinear second order ODE?
A nonlinear second order ODE (ordinary differential equation) is a mathematical equation that involves a function, its derivatives, and possibly the independent variable in a nonlinear way. This means that the function and its derivatives are not directly proportional to each other, making it more difficult to solve compared to linear equations.
Why is it important to solve nonlinear second order ODEs?
Nonlinear second order ODEs can be used to model many physical, chemical, and biological systems. By solving these equations, we can gain a better understanding of how these systems behave and make predictions about their future behavior. Additionally, many engineering and scientific problems involve nonlinear equations, making it crucial to be able to solve them.
What are the methods for solving nonlinear second order ODEs?
There are various methods for solving nonlinear second order ODEs, including separation of variables, substitution, power series, and numerical methods such as Euler's method and Runge-Kutta methods. The choice of method depends on the specific equation and the desired level of accuracy.
How can I check if my solution to a nonlinear second order ODE is correct?
One way to check the correctness of your solution is to plug it back into the original equation and see if it satisfies the equation. Another way is to use a computer program to graph both your solution and the original equation and see if they overlap. If they do, it is likely that your solution is correct.
Are there any general tips for solving nonlinear second order ODEs?
Some general tips for solving nonlinear second order ODEs include trying to simplify the equation by using substitutions, looking for special forms of the equation that can be solved more easily, and breaking the equation into smaller, simpler parts. It is also important to carefully check your work and make sure all steps are mathematically valid.
