Can Oscillating Charges Emit a Hydrogen-Like Spectrum Through Prism Dispersion?
  • Thread starter Hydr0matic
  • Tags
    Harmonics
In summary, the conversation discusses the possibility of an electromagnetic wave, emitted by a charge oscillating vertically and horizontally, producing multiple discrete lines when passed through a prism. It is determined that a sinusoidal oscillation will produce a single spectral line, while any other type of oscillation will produce harmonics and a discrete spectrum. The conversation then delves into the idea of using a wave equation with spherical harmonics to explain the fine structure in the hydrogen spectrum, which may deviate from the original question but is still relevant. The conversation also touches on the concept of a Hertz dipole and the direction of emission for an oscillating electric monopole, ultimately concluding that all emitted waves have the same wavelength due to the sinusoidal nature of
  • #36
hyrdo,
ok - photons(n energy) are created when an electron fall back to its' previous orbit after being bumped to a higher orbit by a photon of the same energy (n) - we are on the same page, and i didn't think you are an idiot.
the other lines in the spectrum (photons) are EACH created by subsequent changes in the possible orbits for the nucleus. every line you see is created by a different photon (frequency).
your idea seems to be that one oscillation is making all these photons? not so. if you want to look at this with wave forms, that is fine. the straight line between the emitter and receiver (90') is all that is required because for every angle above 90', there is a symmetrical angle below 90', and they cancel each other out.
even if this were not the case, the harmonics created by such a small range of frequency change is not enough to produce the wide range seen in the hydrogen spectrum (or others). ie. - you might get a "red" to "red-orange" change, but not orange to violet, and definitely not IR through visible and into UV.
TRoc
  • #37
Well that's the beauty of it :smile: .. By explaining discrete spectra as a result of atomic motion, you don't actually need to infer any energy levels at all. :eek: ... Of all the crazy statements you've ever heard, this takes the cake huh ? :biggrin: ... "We don't need atomic energy levels" .. wow, I even amaze my self.
Ironically, this isn't that far from our current model, is it? We started out with planetary orbits, then energy levels were introduced with fixed orbits. Now, there's a wavefunction for each electron describing the probability of finding it in a certain position.
Is it just me or is this another way of saying "- the electrons are somewhere within the atom" :smile: .. Were it not for the fact that each electron is associated with a certain energy level...
Yes, I realize that. Of course, you need more than one oscillating atom to get a visible spectrum. Like, perhaps, a cloud of atoms oscillating in random directions.
What makes you say it's small? The atoms are oscillating at very high speeds. And the amount of shifting is obviously very depent on the oscillator's speed.
