Can our Nuclear weapons destroy a Neutron Star?
In summary, an average neutron star with a diameter of 10 miles was headed towards Earth. If our technology can provide a direct hit, and do it in time, the Nuke would need to be around 10 Megatons.
Zdenka
43
Does anyone know if an average Neutron star with a diameter of 10 miles, was headed towards Earth.. would our Nuclear weapons be able to physically destroy it? Assuming our technology can provide a direct hit, and do it in time. If so, then how many Megatons would the Nuke need to be, and how many nukes would be required?
Likes Stephanus
Astronomy news on Phys.org
10 mile diameter would mean a radius of 8,047m, and a volume of 2,182,454,900,272 m3. Using an average density of 5 * 1017 kg/m3 gives a mass of about 0.5 solar masses. The largest nuclear bomb ever detonated (Tsar Bomba) was 50 megatons, or about 2 * 1017j. If all that energy was transferred to kinetic energy it would result in a change in speed of 0.00000065 m/s. Keep in mind that is the largest nuclear bomb ever built, and we assumed every single joule would transfer to kinetic energy. In reality the effect would be much smaller.
There is an even bigger problem though. Even if we had enough energy to significantly move the star out of our path it would still mess with orbits. Half a solar mass, could easily move Earth out of our orbit.
Likes Stephanus
The bomb would never make it to the neutron star. Tidal forces would destroy it far before it did.
Likes Stephanus
If you want to blow it APART - the gravitational binding energy of a star is =3/5 GM^2 /r
So a 10km/0.5Msol neutron star = 3/5 * 6.6*10^-11 * (10^30kg)^2/5000m
Is about 10^46 joules,a megaton of TNT is about 5x10^15 Joules.
So you would a mere 10^30 perfectly placed warheads.
Likes Stephanus
Suppose that we're somehow able to slightly deflect the neutron star so that it will collide with the Sun. Then the Sun and the neutron star will merge. The mass could be larger than the critical mass and the whole thing will collapse into a black hole!
Neutron star collision is a likely mode for stellar mass black hole formation in binary star systems. Solo stars tend to blow apart before reaching the critical mass. It is an unlikely scenario in our solar system [fortunately] because our sun does not have a companion [at least not one massive enough to be of concern]. A rogue neutron star could do the trick, but our galaxy is a very large shooting galaxy. The probability is remote. With regard to the initial inquiry, our nuclear devices would be useless. The entire mass of planet Earth could not provide sufficient energy to measurably divert an object of such mass.
I'm reminded of reading a while back that if a marshmallow was to free fall to the surface of a neutron star from about 1 AU, it would hit with the force of a megaton hydrogen bomb due to the NS having an escape velocity of about 80% the speed of light. A megaton is 5e+15 joules which is equivalent to about 45 grams which is about the weight of an egg (which is at least in the region of a marshmallow!) so it looks like what ever hits the surface from free-fall is expected to be completely annihilated, all (or at least very nearly all) of the mass of the object converting to energy.
I think a better option would be to move the Earth AWAY from the path of an incoming Neutron Star!
Whehe :) !
Could anyone calculate how much the orbit of the Earth will be changed if everyone in China jumps at exactly the same time?
Likes Stephanus
That's easy: zero!
Likes Stephanus
russ_watters said:
That's easy: zero!
Shouldn't the Earth's direction theoretically change just a tiny little bit for a tiny little time (for as long as the Chinese people are in mid-air)?
At least, that is what I would expect due to conservation of momentum.
It wouldn't help much if you'd want to avoid hitting a neutron star anyway :p .
Related to Can our Nuclear weapons destroy a Neutron Star?
1. Can our nuclear weapons actually destroy a neutron star?
No, our current nuclear weapons are not powerful enough to destroy a neutron star. Neutron stars are incredibly dense and have a strong gravitational pull, making them nearly impossible to destroy with any known technology.
2. Would a nuclear explosion on a neutron star have any effect?
Yes, a nuclear explosion on a neutron star could potentially affect its outer layers and cause it to release some of its energy. However, it would not be enough to destroy the star itself.
3. How are neutron stars different from regular stars?
Neutron stars are much smaller and denser than regular stars. They are formed when a massive star runs out of nuclear fuel and collapses in on itself, causing its core to become incredibly dense.
4. Could a neutron star be a threat to Earth?
No, neutron stars are typically found in distant parts of the universe and are not a threat to Earth. However, if a neutron star were to collide with a nearby star, it could potentially release a burst of radiation that could affect our planet.
5. Are there any real-life scenarios where we would need to destroy a neutron star?
Currently, there are no known scenarios where we would need to destroy a neutron star. However, studying their properties and behavior can help us better understand the universe and potentially develop new technologies.
