Can photon couple to scalar field?
In summary: In QFT, photons are the carriers of the electromagnetic force. This means that they can interact with other charged particles. However, they don't feel any force at all if they pass between charges.
arroy_0205
129
I have seen in one paper that photon is coupled to dilaton field which is scalar and motivated by string theory. I do not understand this. Photon is carrier of electromagnetic field and so I thought it can only couple to electrically charged fields. Can anyone explain?
Photons can couple to scalar fields. There just happens to be none in the Standard Model (in the spontaneously broken state). Don't want to search for my Rosiek paper now but I am pretty sure the photon couples to the Selectrons of SUSY, for example. In standard particle physics photons only couple to charged fields but in exotic physics they might couple to gravity which the dilaton (according to the WP article; I never encountered those guys myself) seems to be related to.
Scalar fields carry charge as long as they are complex.
Yes that is true but the one I talked about was real scalar field. That is the source of confusion. This I did not write explicitly in my question.
Well, I am not up-to-snuff on string theory per se, but I would say that any scalar object with internal charges, whether they cancel or not, will couple to a photon through a trilinear coupling involving another appropriate vector particle. For neutral scalar mesons, for example, the coupling to two photons is an available channel...
photons can couple to fields that are electrically neutral through higher-dimension operators (and therefore are suppressed). All you need to do is maintain gauge and Lorentz invariance, so for example (with a real scalar field [itex]\phi[/itex]):
[tex]\phi F_{\mu\nu}F^{\mu\nu}[/tex]
is allowed. However, it's physical effects are typically quite small. But this is how you can describe photons scattering off (neutral) atoms in the atmosphere, for example.
Thanks everybody for your responses. These were really helpful for me.
Hi:
In QFT, photons are the carriers of the electromagnetic force, right?, Does that mean that if photons pass between charges , they don't feel any force at all?
I am a little bit confused about how the interactions occur in QFT, I'd be glad if you could please explain me
Thanks
FAQ: Can photon couple to scalar field?
1. Can a photon interact with a scalar field?
Yes, a photon can couple to a scalar field. This interaction is known as a "photon-scalar coupling" and is a fundamental process in quantum field theory.
2. What is the role of the scalar field in this interaction?
The scalar field plays a crucial role in this interaction as it provides a medium for the photon to interact with. The photon acquires mass through its interaction with the scalar field, which is essential for some theories of particle physics.
3. How is the coupling strength between a photon and scalar field determined?
The strength of the coupling between a photon and scalar field is determined by the coupling constant, which is a fundamental parameter in the theory. This constant is typically determined through experimental measurements.
4. Can this coupling exist in nature?
Yes, the photon-scalar coupling is a well-established phenomenon in nature. It has been observed in various physical systems, including in the interactions between particles in the Standard Model of particle physics.
5. What are the implications of this coupling for our understanding of the universe?
The photon-scalar coupling has significant implications for our understanding of the universe. It helps explain the behavior of particles and their interactions, and has been crucial in the development of modern theories such as the Standard Model and quantum field theory.
