Can Photons travel faster than c?
In summary, the conversation discusses conflicting answers regarding the probability of a photon being detected at two different points in time, with some sources mentioning a small but non-zero probability outside the light cone and others saying it is impossible for a photon to travel faster than the speed of light. The conversation delves into the use of the path integral formalism in quantum field theory and how it accounts for classically forbidden paths. It is noted that the paths in the path integral are not actual particle paths and the probability density at a point outside the light cone is still zero, despite some paths having non-zero probabilities. The use of negative probabilities and the relation to antiparticles is also mentioned.
Electric to be
152
I've looked up this question on the web, and I've gotten seeming conflicting answers.
According to Feynman's path integral - to find the probability of a photon being at A at time 1 and B at time 2 can be determined by taking an integral of the photon traveling over all possible paths. I understand that these paths more than anything are mathematical constructs and should not be taken super literally (since classical trajectories don't really make sense for quantum particles)
Regardless, I have seen on the internet that for points outside of the light cone, the integral results in very low probability of photons being detected, but still nonzero. This effect apparently becomes more significant for very small distances, and goes to zero at larger distances. This would mean there is an exponentially decaying probability of the photon having a speed greater than c. However, in other places I've seen people say pretty strictly that no it is not possible for the photon to have even slightly larger values of c. Even still, I've seen people say that while the photon may travel faster than c, information cannot. This I don't understand. If a photon is known to have been emitted at time 1, and absorbed at time 2, and this is faster than the speed of light - how did information not travel at the same speed? Though I know this has some implications on Causality..
So what is the truth?
Thanks.
No particle can travel faster than the speed of light in vacuum. I suspect that you are seeing a non vanishing probability density outside the light cone because you are not using the relativistic formulation of quantum mechanics. Are you solving the Schrödinger Eq., the Dirac Eq., or the Klein Gordon Eq. ?
Well I'm not solving anything - I was referring to what others have said about the matter. I was referring to the path integral in quantum field theory ( relativistic) for a photon.
If it's quantum field theory they are probably solving the Klein-Gordon equation. This equation is Lorentz invariant and should not allow faster than light solutions.
One thing to consider is that these paths are not really true particle paths. If they were then this would be classical mechanics and not quantum mechanics. It turns out however, that when you use the path integral formalism for a quantum particle you get the same probability density as you would if you use a propagator (the traditional approach). Some of these paths are classically forbidden, such as the faster than light paths you mention, but they are all required to sum to the correct probability amplitude.
Now all this assumes that your point "b" is in the light cone centered at point "a". If your end point "b" moves outside of this light cone then all of these paths should cancel each other out to give a total probability amplitude of zero.
I'm no expert in QM, but I always thought QFT was a separate animal, and left behind Schrodinger, Dirac, and Klein-Gordon equations for the "path integral formalism". But that is slightly digressing.
While I'm not sure how reliable, here is an external link :
https://www.quora.com/When-analysin...ove-faster-than-light-to-reach-B-at-the#!n=12
I've seen in other locations as well, that the summation due to classically forbidden terms are small, but the overall summation is still nonzero.
Right, this is what I meant by saying "they are all required to sum to the correct probability amplitude." When the particle moves from point a to b, it does not do so by following some path between the two points but instead it propagates as a field. The path integrals aren't necessarily the actual paths being followed by the particle so there is no reason to believe anything is traveling faster than light.
The important part is that if point b is outside of point a's light cone then the probability density at point b is zero even if the probabilities for individual paths are non-zero. You might think "hey if some paths have probabilities that are non-zero then do some paths need negative probabilities to get a total of zero at point b?" The answer is of course YES. The Klein-Gordon equation allows for negative probability densities, this is related to antiparticles.
But the point he was trying to make was that the overall summation (sum of all the paths) was non-zero, so the probability density would be non-zero. He goes on to explain that even so this doesn't violate Causality.
I think the confusion may be coming from the fact that the path integral formulation used often relies on a WKB approximation. This means that the propagator may give non vanishing solutions outside the light cone where the approximation is not as good. The exact solution however will always be zero outside the light cone. Here is a link to a paper going into some detail on this. https://arxiv.org/pdf/gr-qc/9210019.pdf
Where? Please give a reference. And if it isn't a textbook or peer-reviewed paper, be prepared to be told that it isn't a valid reference and you should look at textbooks or peer-reviewed papers.
And this applies for photons in particular?
Well unfortunately I don't have any at the moment. The idea of what I was talking about is posted above in the Quora link, though. However, apparently Feynman said this exact same thing. That there is a probability of this occurring, however small, especially at small distances. He says: "The amplitudes for these possibilities are very small compared to the contribution from speed c; in fact, they cancel out when light travels over long distances."
It would apply to any particle.
Got it. However, as I posted above Feynman said (extended version):
"It may surprise you that there is an amplitude for a photon to go at speeds faster or slower than the conventional speed, c. The amplitudes for these possibilities are very small compared to the contribution from speed c; in fact, they cancel out when light travels over long distances. However when distances are short... these other possibilities become vitally important and must be considered." Pg 89 QED
Implying at shorter distances, they wouldn't necessarily cancel out. Is this in contrast with what you said?
This is an "I" level thread. That means you are assumed to have undergraduate level knowledge of the subject matter. Such knowledge is normally obtained by studying at least some textbooks or peer-reviewed papers. Have you studied any?
Note carefully this statement from the Quora link:
"no measurement can affect any other measurement outside of its lightcone."
What that means is that, if we have two measurements that are spacelike separated, their results can't affect each other. So if one "measurement" is the emission of a photon, and the other "measurement" is the absorption of a photon, neither one can affect the other. That is why it is said that no information can be transmitted in this manner--information transmission requires the "source" to be able to affect the "receiver" in some controllable way.
Also, you have to be careful not to assume that the photon emitted at one event and the photon detected at the other event are "the same" photon. Photon's don't have little identity labels on them. You can say that a photon was emitted at event A and a photon was detected at event B, but you can't say the two are "the same" photon.
Pg 89 QED
As good as this book is, it's still a pop science book, not a textbook or peer-reviewed paper. As such, it leaves out things. For example, it says that "these other possibilities are vitally important and must be considered", but it doesn't (IIRC) say exactly what they must be considered for.
Also, you have to be careful not to assume that the photon emitted at one event and the photon detected at the other event are "the same" photon. Photon's don't have little identity labels on them. You can say that a photon was emitted at event A and a photon was detected at event B, but you can't say the two are "the same" photon.As good as this book is, it's still a pop science book, not a textbook or peer-reviewed paper. As such, it leaves out things. For example, it says that "these other possibilities are vitally important and must be considered", but it doesn't (IIRC) say exactly what they must be considered for.
Well alright. I have seen similar statements on forums such as PhysicsStack and while I agree it may not be a peer reviewed source it's just confusing hearing this seemingly conflicting statements - especially from the likes of somebody like Feynman. What is your take on the matter? Is a non-zero probability of detecting outside of the light cone nonsense? Or is something like what was said on Quora close to the truth - photons may travel faster than c, but will not violate causality? I just seem to be getting somewhat conflicting answers.
No.
No. You have assumed that the photon emitted and the photon detected are "the same photon", which "travels" between the two events. You can't assume that. Go back and read my previous post again.
No, you're failing to recognize that you are making implicit assumptions which are false.
PeterDonis said:
No.
Well then how can we ever talk about the concept of photons moving at a particular speed, if it is not the time between the movement of nonzero probability? It doesn't matter to me if it's one photon or another, if the probability of photon being detected at point B after being emitted at point A at time X seconds, then that is good enough for the speed of a traveling photon?
In certain situations, this is a good enough approximation and it greatly simplifies the analysis. But it is only an approximation, and in many situations, such as the one under discussion here, it breaks down.
if the probability of photon being detected at point B after being emitted at point A becomes nonzero after x seconds, then that is good enough for the speed of a traveling photon?
No. See above.
No. See above.
Alright. I guess I'll just accept that I won't really understand the matter fully since I don't have much formal training in QFT. Thanks anyway.
The speed of photons in vacuum are derived in electromagnetism. You would first need the maxwell equations to get to that. Look for example here where they arrive at this result in (453):
http://farside.ph.utexas.edu/teaching/em/lectures/node48.html
The speed of photons is slower if it is not vacuum. This is also derivable from the fundamental electromagentic equations.
schrødinger is based on a differential equation that is based on maxwell equations. They also use the fact that the speed of photons are c in the derivation of schrødinger.
I am fully aware of the wave equation in classical electromagnetism, and that light moves at c in all reference frames according to these equations. That wasn't the concern here. Classical electromagnetism (Maxwell's equations) also are not a description of photons. That requires Quantum Field Theory, and is the issue that I was concerned with here.
I'm also not sure what you mean about using Maxwell's equations in the derivation of Schrodinger's equation. Schrodinger's equation is non-relativistic. That's diverging from the topic anyways.
Likes georg gill
The word "photon" doesn't even appear in that piece, and it is quite clear that they are talking about the speed of electromagnetic waves , not photons.
There have been efforts to motivate Schrodinger's equation by analogy with E&M, but it is a huge stretch to call any of these attempts "derivations". A proper derivation can be found in advanced textbooks such as Sakurai, and there's an outline of such a derivation in the Wikipedia article for "Schrodinger equation"; neither the invariance of ##c## nor Maxwell's equations are involved.
No. See above.
If I may ask though, in what situations is it valid? Why do people so often say that photons "only go at the speed of light, c" when situations like this break down this sort of notion? I know that for longer distances, the probability of detection is also essentially zero outside the lightcone. Is it valid in situations where the speed of information matches the speed of photon detection, so essentially for longer distances?
Clearly on a macroscopic classical sense, EM waves are only observed to go at C, but of course we aren't talking about photons here.
Why do people so often say that photons "only go at the speed of light, c"?
Because they're speaking carelessly, and they should have said "light signal" or "flash of light" or "wavefront" instead of "photons".
One hint: Before thinking about QFT start with classical electrodynamics, if it comes to photons. There in the very early days of special relativity this question has troubled the famous experimentalist Willy Wien: He knew very well that electromagnetic waves can have phase and group velocities larger than ##c## in media, around a resonance. The phenomenon is known as "anomalous dispersion". Principally this apparent contradiction to SRT was as quickly solved by the famous theorist Arnold Sommerfeld in an article taking about half a page to show that there is nothing traveling faster than ##c## that is not "allowed" to do so by SRT, which is no surprise since classical electrodynamics is the paradigmatic example of a relativistically covariant local classical field theory. The problem was worked out in much more detail by Sommerfeld himself and Brillouin, where they explicitly calculated the wave form of an em. wave train entering a medium in the region of frequencies of anomalous dispersion. It comes out that within their model the wave front in fact moves with ##c## (i.e., with the speed of light in vacuo), because the medium hasn't had time to respond to the field yet and thus is doing nothing to the wave front. Then you have some transient state, where very rapidly oscillating "precursors" occur (there can be two types, the Sommerfeld and the Brilloin precursor depending on the details of the parameters of the dielectric function of the medium) which then go over into the steady state, where the field inside the medium is a wave with the same frequency as the incoming wave, which is what you usually have in mind when describing the situation with the Fresnel equations: This implicitly assumes that the wave field is present for a sufficiently long time within the medium such that the transient states all are damped away, and the steady state is reached. This cannot happen at speeds faster than the speed of light in vacuum, since the wave front travels at this speed, i.e., nothing happens earlier than the time of the head of the wave needs to travel in the vacuum to reach a certain position in the medium, i.e., before that time there's neither a response of the medium nor a field different from 0.
Likes Tio Barnabe and bhobba
Is there any experimental proof for this?
I know no particle can, but I am interested in the proof. :wink:
A particle accelerator.
There is no such thing as a proof in physics. That's for math. You can only ask is there any observational evidence for ... and is there any observational evidence against ...
Evidence FOR something does not prove it
Which is just observational evidence and most emphatically not a proof
No. Experiments can't "prove" anything. But they can give evidence for it. The evidence is extremely strong that no particle can travel faster than the speed of light in a vacuum. That's the best you're going to get.
Several posts about the day to day activities of physicists have been removed. Such posts would belong in a new thread in the Career Guidance section.
Likes rauf_zargar and ISamson
  • #31
I think its a confusion even I had a few years ago, but was corrected by Orodruin and I felt utterly silly I didn't see it.
In the path integral you have to include even paths that travel faster then light (off shell). I thought the fact that nothing can travel FTL meant they weren't really included - but of course they must be. It doesn't mean anything is actually traveling FTL - but it must be included in the calculations. Not making such a distinction can lead to confusion and perhaps that's what the OP is getting at:
https://en.wikipedia.org/wiki/On_shell_and_off_shell
Its part of the virtual particle thing that confuses many. To the OP there are a number of myths in QM and its wise to become acquainted with them - this virtual particle thing is one of the most insidious:
https://arxiv.org/pdf/quant-ph/0609163.pdf
Thanks
Bill
  • #32
This is explained very well in Padmanabhan's QFT textbook
https://www.amazon.com/dp/3319281712/?tag=pfamazon01-20
Sec. 1.5.2. The field operator can be split into a "particle" part and an "antiparticle" part. If you consider the commutator of the particle part only (or the antiparticle part only), then the commutator is small but non-zero at space-like distances. However, if you consider the commutator of the full field operator, then it vanishes exactly at space-like distances. This demonstrates that only the full field, not its "particle" and "antiparticle" parts, is a physical observable. In other words, some auxiliary mathematical objects of QFT can "travel" faster than light, but no physical observable of QFT can do that.
Likes vortextor, bhobba and entropy1
  • #33
Yes, and that's the reason, why there must be always a particle and an antiparticle part in the field operator. At the same time only with both parts you get a local realization of the proper orthochronous Poincare group in the "canonical" way and, when obeying the spin-statistics theorem, an energy bounded from below. So locality, microcausality, and stability (existence of a ground state) all together lead to the idea of local field operators and the necessity of antiparticles in addition to particles (of course with the option that particles and antiparticles are the same).
Likes bhobba
  • #34
I don't understand this.
Is it possible to prove something in physics using mathematical proof and concepts, yes or no?
I always thought it can.
Or is there just strong evidence (what do you mean by evidence, @PeterDonis ??) for something that you just assume there can't be anything else?
Thank you, please forgive my misunderstanding.
  • #35
A proof in the scientific sense can only be given within mathematics, starting from a system of axioms and then using the rules of logic to prove theorems, lemmas, and however the mathematicians call their results. Mathematics in this sense is a set of rules of our mind. It's not a priori referring to anything in Nature.
With the discovery of the natural sciences in the 17th century (I'd say Kepler, Galileo, and Newton were the first famous figures in the history of modern natural sciences) it has turned out that mathematics is the only adequate language to make precise statements about objective "reality", where I understand "reality" as the objectively observable and quantifiable entities investigated by the natural sciences.
Of course, already much earlier, e.g., in ancient Egypt and Greece, one has used mathematics for practical purposes, most importantly geometry and arithmethics to organize daily life.
That math is such a successful tool in various branches of sciences (reaching from the natural sciences over engineering to economy and sociology) is in my opinion understandable by the fact that many mathematical subjects have been invented using everyday experience and thus are related to "reality" in the above understood sense. E.g., Euclidean geometry has been abstracted from our everyday experience of how bodies around us relate and how distances and directions can be quantified. This holds true even for more abstract subjects like functional analysis which has to a large extent been invented by the mathematicians to make sense of some ideas reaching back to Heaviside in electromagnetic theory ("operator calculus") and Dirac et al in developing modern quantum theory (theory of generalized functions, aka distributions, eigenvalue problems leading to the work by Hilbert, von Neumann, Schwartz et al).
In other cases math was first in inventing very useful theories for application to the natural sciences. E.g., a purely mathematical problem of interest in the 19th century came up when the mathemticians were asking themselves, whether one can prove the axiom of parallels of Euclidean geometry (which itself has undergone a revision by Hilbert et al, making the hidden assumptions on "the continuum" used without being mentioned by the ancient Greeks), leading to the development of non-Euclidean geometry and later on differential geometry and Riemann spaces, later useful for Einstein (after he had been tutored by his old friend Grossmann about this math ;-)) in the devolopment of the General theory of Relativity.
Now the natural sciences are distinct from math already by the fact that the natural sciences aim at describing objective reality or, put more carefully, our observations of objective reality using our senses and technical devices to extent our senses to the utmost small (atomic and subatomic scales) and the utmost large (astrophysical and even cosmological scales) and making everything quantitative and thus precisely analyzable by mathematical means. A physical model thus can never ever be proven in the strict sense a mathematical theorem is proven within a given axiomatic system, but one can test it at higher and higher accuracy by making progress in the development in ever more precise ways to observe and measure phenomena. So, if a physicist is telling you, "one has proven that and that model or theory", it means that so far even the most precise measurements confirmed the predictions of the model. Of course, within a given theory you can have mathematical proofs (like the Heisenberg uncertainty principle from the basic postulates of quantum theory), but this is not a "proof" that the underlying postulates concerning the physics are correct. Instead, the mathematical facts of a physical theory of this kind, may inspire some experimental physicist to new experimental/observational tests of the theory, and the outcome of such new tests always can be that we discover where our contemporary theories fail to explain an observed and measured phenomenon. Then the theoreticians have new work to get even better models, and they have to understand why the old models worked within their range of applicability (e.g., Newtonian mechanics can be understood as an approximately valid limit of relativistic mechanics).
Likes ISamson and bhobba
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
