MHB Can Power Sets of Equinumerous Sets Remain Equinumerous?
  • Thread starter Thread starter issacnewton
    Power Sets
The discussion revolves around proving that if a set A with at least two elements satisfies \( A \times A \sim A \), then \( \mathcal{P}(A) \times \mathcal{P}(A) \sim \mathcal{P}(A) \). Participants explore various set theory identities and properties, including the relationships between power sets and Cartesian products. The proof involves demonstrating that \( \mathcal{P}(A) \) can be expressed in terms of subsets and applying transitive properties of equinumerous sets. Ultimately, the conclusion is reached using the Cantor-Schroder-Bernstein theorem, affirming the original statement. The complexity of the proof raises questions about potential simplifications.
issacnewton
Hi
Here is the problem. Let A be a set with at least two elements. Also suppose.
\[ A\times A \sim A \]
Then prove that
\[ \mathcal{P}(A)\times \mathcal{P}(A)\sim \mathcal{P}(A) \]
Let a and b be the two elements of this set. Then I want to exploit the result that
\[ \mathcal{P}(A)\;\sim ^{A}(\{a,b\}) \]
and I also want to exploit the result that if C and D are disjoint sets, then
\[ \mathcal{P}(C\cup D)\;\sim \mathcal{P}(C)\times \mathcal{P}(D) \]
I tried playing around with this but couldn't get the result. Any ideas ?
IssacNewton said:
Hi
Then prove that
I could prove only the fact that,
$$ \mathcal{P}(A\times A)\sim \mathcal{P}(A) $$
Now, just show that,
$$ \mathcal{P}(A\times A)\sim \mathcal{P}(A)\times\mathcal{P}(A) $$
(I don't sure if it's true!)
And you done. (Why?)
HiGot the solution...
I am going to use the following identities in set algebra which deal
with equinumerous sets. I had asked the help for the proofs on
many identities at MHF and eventually posted the solutions there.
But now MHF is not there, all that work is lost... So here are the
identities I am going to use.. I have proved these before...1) For any set A \[ A\;\precsim\mathcal{P}(A) \]
2)For any sets A,B,C \[ ^{A}(B\times C)\;\sim\; ^{A}B\times\; ^{A}C \]
3) \[ C\subseteq D \Rightarrow C\precsim D \]
4)For any sets A,B,C \[ ^{(A\times B)}C\;\sim\; ^{A}( ^{B}C) \]
5)For any set A, \[ \mathcal{P}(A)\;\sim\; ^{A}\{1,0\} \]
here we can replace 1 and 0 by any other elements.
6)if \( A\;\precsim B\) and \( C\;\precsim D \) then
\[ A\times C\;\precsim B\times D \]
7)if \( A\;\precsim B\) then \[ \mathcal{P}(A)\precsim \mathcal{P}(B) \]
8)if \(A\neq\varnothing\) and \( A\;\precsim B\) and \( C\;\precsim D \)
then \[ ^{A}C\;\precsim\; ^{B}D \]
9)if \(A\cap B=\varnothing \) then
\[ \mathcal{P}(A\cup B)\;\sim \mathcal{P}(A)\times \mathcal{P}(B) \]so here is the solution I got. since A has at least two elements, let
them be a and b . Now define, \( B=A\setminus \{a,b\} \). Using rule 9, we
have \[ \mathcal{P}(B\cup \{a,b\})\;\sim \mathcal{P}(B)\times \mathcal{P}(\{a,b\}) \]\[ \therefore \mathcal{P}(A)\;\sim \mathcal{P}(B)\times \mathcal{P}(\{a,b\}) \]which means
\[ \mathcal{P}(A)\;\precsim \mathcal{P}(B)\times \mathcal{P}(\{a,b\}) \]
Now \( B\subseteq A\) and \( \{a,b\}\subseteq A\), using rule 3 we have\[ B\;\precsim A\;;\;\{a,b\}\precsim A \]so using rule 7 we have\[ \mathcal{P}(B)\;\precsim \mathcal{P}(A) \;;\;\mathcal{P}(\{a,b\})\;\precsim \mathcal{P}(A)\]using rule 6, we get\[ \mathcal{P}(B)\times \mathcal{P}(\{a,b\})\;\precsim \mathcal{P}(A)\times \mathcal{P}(A) \]since \( \precsim \) is transitive , we have \[ \mathcal{P}(A)\;\precsim \mathcal{P}(A)\times \mathcal{P}(A) \cdots (E1)\]
Now \( \mathcal{P}(A)\;\sim\; ^{A}\{a,b\} \) so using rule 6 (but for equinumerous sets), we have\[ \mathcal{P}(A)\times \mathcal{P}(A)\;\sim\; ^{A}\{a,b\}\times ^{A}\{a,b\} \cdots (E2)\]using rule 2 we get\[ ^{A}\{a,b\}\times ^{A}\{a,b\}\;\sim\; ^{A}(\{a,b\}\times \{a,b\}) \cdots (E3)\]since \( \{a,b\}\;\precsim A \) , using rule 6 we get\[ \{a,b\}\times \{a,b\}\;\precsim A\times A \]but we have been given \( A\times A\;\sim A \), which implies that
\( A\times A\;\precsim A \), so using transitivity of \(\precsim\) we get\[ \{a,b\}\times \{a,b\}\;\precsim A \] Now we notice that for set A we have \( A\;\precsim A\) , and since
\( A\neq\varnothing \), using rule 8 we have\[ ^{A}(\{a,b\}\times \{a,b\})\;\precsim\; ^{A}A \cdots (E4)\] but using equations E2 ,E3 and E4 , we get \[ \mathcal{P}(A)\times \mathcal{P}(A)\;\precsim ^{A}A \cdots (E5)\]Now, \( A\;\precsim \mathcal{P}(A) \) using rule 1 and also we have
\( A\;\precsim A \). Since \( A\neq\varnothing \), using rule 8 we have
\( ^{A}A\;\precsim ^{A}\mathcal{P}(A) \). So using E5 we get\[ \mathcal{P}(A)\times \mathcal{P}(A)\;\precsim\; ^{A}\mathcal{P}(A) \cdots (E6)\]Now \( A\;\sim A\) and \( \mathcal{P}(A)\;\sim ^{A}\{a,b\} \) and since
, using rule 8 (but for equinumerous sets), we have\[ ^{A}\mathcal{P}(A)\;\sim\; ^{A}( ^{A}\{a,b\}) \cdots (E7)\]using rule 4 we get\[ ^{A}( ^{A}\{a,b\})\;\sim\; ^{(A\times A)}\{a,b\} \cdots (E8)\] But \( ^{(A\times A)}\{a,b\}\;\sim \mathcal{P}(A\times A) \) using rule 5, So
using E7 and E8 and transitivity of \(\sim\) we get
\[ ^{A}\mathcal{P}(A)\;\sim \mathcal{P}(A\times A) \] Now using rule 7 (but for equinumerous sets), we have\[ \because A\times A\;\sim A \Rightarrow \mathcal{P}(A\times A)\;\sim \mathcal{P}(A) \]\[ \therefore ^{A}\mathcal{P}(A)\;\sim \mathcal{P}(A) \]\[ \therefore ^{A}\mathcal{P}(A)\;\precsim \mathcal{P}(A) \] so using E6 we have\[ \mathcal{P}(A)\times \mathcal{P}(A)\;\precsim \mathcal{P}(A) \cdots (E9)\]Using E1 and E9 , it follows from Cantor-Schroder-Bernstein theorem that\[ \mathcal{P}(A)\times \mathcal{P}(A)\;\sim \mathcal{P}(A) \]It seems too long for me. Is there a shorter way to get this ? its a lot of typing...(Whew)Thanks
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
