Can radiation particles contribute to heat transfer in space?
In summary, EM radiation will in general impart energy to whatever it comes in contact with and will heat it up. The earth, its atmosphere, satellites in orbit, comets and anything else out there are all subject to the effects of EM radiation. BTW, it is not a 'dose.' does = does this or that happen. dose = I will give you your dose of medicine to make you well. witch = casts spells and does incantations. which = used referring to something previously mentioned."
mike foster
Freon is used every day to reduce temperature by compressing the gas then releasing the pressure. The Question is dose radiation from the sun (witch would be high pressure) steal energy from the objects it comes in contact with in space (witch is low pressure), Thus contribute to the loss of heat in space? dose radiation act the same as other mater in pressure to non pressure states?
Science news on Phys.org
no, EM radiation will in general impart energy to whatever it comes in contact with and will heat it up ...
the earth, its atmosphere, satellites in orbit, comets and anything else out there
BTW it is does not dose
which = used referring to something previously mentionedDave
sorry spelling is not a strong subject for me or grammar. Thank you for the answer.
Likes davenn
no probs :smile:
hope the answer to your Q was useful
"Freon is used every day to reduce temperature by compressing the gas then releasing the pressure."
I think your understanding of refrigeration cycles needs improving because it has lead you astray when it comes to other areas. Pressure is not the driver for heat transfer, temperature is. Here is a brief outline of an ideal gas refrigeration cycle.
  1. A gas is compressed, so it goes to a higher P and a higher T than ambient (high T is needed for step 2).
  2. The gas is then allowed to cool, at a constant P, by heat transfer to the ambient. This lowers the T of the gas.
  3. Then the gas is throttled, which lowers the P and brings the T to below that of the refrigerated space (low T is required for step 4).
  4. Finally, the gas is heated at constant P by heat transfer from the refrigerated space. This increases the T of the gas on its way back to step 1.
This cycle repeats over and over with the gas. Throughout the cycle, pressure is manipulated as a proxy to control temperature, which is the property that determines the heat transfers. Pressure, of itself, is not actually aiding in the heat transfers that need to take place - that is determined entirely by temperature.
I hope this helps. :-)
Related to Can radiation particles contribute to heat transfer in space?
1. Can radiation particles contribute to heat transfer in space?
Yes, radiation particles can contribute to heat transfer in space. Radiation is one of the three main methods of heat transfer, along with conduction and convection. In space, where there is no medium for conduction or convection, radiation is the only way for heat to be transferred.
2. How do radiation particles transfer heat in space?
Radiation particles, also known as photons, transfer heat through electromagnetic waves. These waves are emitted by hot objects and travel through space until they are absorbed by another object, which then increases in temperature.
3. Can radiation particles transfer heat through a vacuum?
Yes, radiation particles can transfer heat through a vacuum. Unlike conduction and convection, which require a medium, radiation can travel through a vacuum. This is why heat from the sun can reach the Earth even though there is empty space between them.
4. Does the amount of radiation particles affect the amount of heat transfer in space?
Yes, the amount of radiation particles can affect the amount of heat transfer in space. The more radiation particles present, the more heat can be transferred. This is why objects that are hotter emit more radiation and can transfer more heat to cooler objects.
5. How does the intensity of radiation particles affect heat transfer in space?
The intensity of radiation particles refers to the concentration of photons in a given area. The higher the intensity, the more photons there are to transfer heat. Therefore, objects with a higher intensity of radiation particles will transfer more heat than those with a lower intensity.
  • Thermodynamics
  • Thermodynamics
10K
  • Thermodynamics
  • Classical Physics
  • General Engineering
