Can random walks be applied to String Theory in curved space
In summary, random walks can be used to model particles in String Theory by simulating their motion in both flat and curved spaces. They relate to the fundamental principles of String Theory by incorporating the idea of random and unpredictable movement while still following certain laws. However, they have limitations and should be used in combination with other techniques to gain a more accurate understanding of String Theory.
jinawee
28
If we study the high temperature limit (near Hagedorn) of a string gas, most of the energy is concentrated in a single long string. If we model the string by a fixed number of rigid links of length ls and calculate the number of possible configurations, we get the density of states:
$$\omega(E) \sim \frac{ e^{ \beta E} }{ E^{ 1+D/2 } }$$
Is it possible to generalize this method in curved space?
A possible way is to calculate the torus path integral of a string that wraps the euclidian periodic time in a curved background. At high temperatures this can be calculated from the path integral of a single non-relativistic particle, which gives the free energy and thus the density of states. This seems to be called the random walk model. References: http://arxiv.org/abs/1506.07798 and http://arxiv.org/abs/hep-th/0508148 .
But this seems totally different. A particle path can be related to a random walk, but one doesn't calculate the number of microstates from combinatoric reasoning. Is there a way to do something like that?
Thank you for your question. The method you describe is commonly known as the random walk model in string theory, and it is indeed different from the method used to calculate the density of states in the high temperature limit. The random walk model is based on the idea that a string can be viewed as a collection of non-interacting particles moving in a curved background. This allows for the calculation of the string partition function and thus the density of states.
However, as you correctly pointed out, this method is not based on combinatoric reasoning and does not directly calculate the number of microstates. In order to generalize this method in curved space, one could potentially use the same approach of calculating the string partition function in a curved background, but with the inclusion of string interactions. This would require a more sophisticated mathematical framework and may not be as straightforward as the random walk model.
Another possible approach could be to use the formalism of statistical mechanics in curved space, which has been developed in the context of black hole thermodynamics. This formalism takes into account the effects of curvature on the statistical properties of a system and could potentially be applied to string theory in curved space.
In summary, while it is possible to generalize the random walk model in curved space, it may require the use of more advanced mathematical techniques and a deeper understanding of the statistical mechanics of curved systems. I hope this helps to answer your question.
Related to Can random walks be applied to String Theory in curved space
1. Can random walks be used to model particles in String Theory?
Yes, random walks can be applied to String Theory as a way to model the motion of particles in a curved space. Random walks involve a series of steps taken in random directions, which can represent the unpredictable movement of particles in quantum mechanics.
2. How do random walks relate to the fundamental principles of String Theory?
Random walks are used in String Theory to simulate the behavior of particles at a quantum level. They are based on the idea that particles can move in a random, unpredictable manner and still follow certain laws and principles, such as the laws of conservation of energy and momentum.
3. Can random walks be applied to both flat and curved spaces in String Theory?
Yes, random walks can be applied to both flat and curved spaces in String Theory. In flat space, random walks are used to model the movement of particles in a uniform environment. In curved space, random walks can be used to simulate the behavior of particles in a non-uniform environment, such as near a black hole.
4. How accurate are random walks in modeling particles in String Theory?
Random walks are a simplistic model and do not capture all the complexities of particle behavior in String Theory. However, they can provide valuable insights and approximations for understanding the behavior of particles in curved space.
5. Are there any limitations to using random walks in String Theory?
Yes, there are limitations to using random walks in String Theory. They do not take into account the effects of quantum fluctuations and other factors that can influence the behavior of particles. Therefore, they should be used in combination with other modeling techniques to gain a more complete understanding of String Theory.
  • Beyond the Standard Models
