MHB Can Set Union Have an Additive Inverse Like Real Numbers?
paulmdrdo1
1.show that there is no axiom for set union that correspond to "Existence of additive inverses" for real numbers, by demonstrating that in general it is impossible to find a set X such that $A\cup X=\emptyset$. what is the only set $\emptyset$ which possesses an inverse in this sense?
2. show that the operation of subtraction is not commutative,that is, it is possible to find real numbers a and b such that $b-a\not = a-b$. what can be said about a and b if $b-a=a-b?$
what to do? i don't understand what question 1 is asking.
Question 1 asks you to find a set $A$ such that $A\cup X\ne\emptyset$ for all sets $X$. Such $A$ is a counterexample to the property
For every $A$ there exists an $X$ such that $A\cup X=\emptyset$ (*)
which is an analog of the "Existence of additive inverses" for real numbers. It also asks to find a unique set $A$ for which (*) is true.
If A is non-empty (for concreteness, let A = {a}), then A U X is also non-empty, because no matter what X is, A U X contains at least the element a.
Thus if A U X = Ø (for some X) it must be the case that A = Ø. What must X be, here?
X must also be empty. am i right? and evegenymakarov what does this symbol mean (*)?
Yes.
I denoted the statement "For every $A$ there exists an $X$ such that $A\cup X=\emptyset$" by (*) in order to refer to it later. This is often done in math texts. The label like (*) or (1) is usually located near the right page margin.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
