Can small magnetic fields on Mars repel deadly radiation?
In summary, the conversation discusses the idea of using a magnet to create a magnetic field around Mars to protect it from solar radiation and other background radiation from space. However, it is determined that the magnet would have to be very large and strong, potentially causing issues with using superconductors and cooling normal conducting coils. It is suggested that using a layer of rock may be a more feasible solution.
Alex299792458
38
Since Mars doesn't have a magnetic field of its own due to the cooling of it's core, what if you took a strong magnet from Earth say a superconductive magnet or electromagnet, will the small magnetic field (relative to mars) repel solar radiation, solar flares and other background radiation form space?
The field would have to be really massive and strong. As rough estimate, the product of magnetic flux density (in Tesla) and distance should be similar. The magnetic field of Earth has about 50 microtesla and thousands of kilometers, if you want to reduce this to 10 meters you need tens of tesla. The strongest large magnets (larger than a meter) have a few tesla, and going significantly above that would be really problematic. You cannot use superconductors above a certain field strength, and cooling normal conducting coils is problematic as well.
Using some layer of rock looks much easier.
Related to Can small magnetic fields on Mars repel deadly radiation?
1. How can small magnetic fields on Mars repel deadly radiation?
Small magnetic fields on Mars can repel deadly radiation by deflecting charged particles from the sun, known as solar wind, away from the planet's atmosphere. This creates a protective barrier that helps shield Mars from harmful radiation.
2. Why is it important for Mars to have magnetic fields to protect against radiation?
Mars has a very thin atmosphere and lacks a global magnetic field like Earth, which means it is more vulnerable to harmful radiation from the sun. A protective magnetic field can help preserve Mars' atmosphere and make it more habitable for potential future human exploration.
3. How do scientists know that Mars used to have a stronger magnetic field?
Scientists have discovered magnetic minerals in ancient rocks on Mars that are only formed in the presence of a strong magnetic field. This suggests that Mars may have had a stronger magnetic field in the past, but it has weakened over time.
4. Could humans use technology to create a magnetic field on Mars?
It is theoretically possible for humans to create a magnetic field on Mars using technology, but it would require a lot of energy and resources. It is currently not a feasible solution for protecting the planet from radiation.
5. Can other planets in our solar system also have magnetic fields that protect against radiation?
Yes, other planets in our solar system, such as Earth, Jupiter, Saturn, Uranus, and Neptune, also have magnetic fields that help protect against radiation. However, the strength and size of these magnetic fields vary greatly among different planets.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
9K
  • Astronomy and Astrophysics
