iknowsigularity
- 39
Can anyone provide me with a simple explanation for why e^i(x) acts like this.
DuckAmuck said:another remarkable relation is that i^i ~ 0.2.
Another intuitive explanation: Remember that d/dx( eix ) = i*eix. That means that as real values of x increase from 0, eix starts at ei*0 = 1 and it always moves at an exact right angle to it's current radius vector from 0. So it goes around the unit circle in the complex plane. Looking at its real and imaginary part, you see that they match the cos(x) and i*sin(x), respectively.iknowsigularity said:Can anyone provide me with a simple explanation for why e^i(x) acts like this.
The equation e^i(x) = cos(x) + isin(x) is known as Euler's formula, and it is a fundamental relationship in complex analysis. It states that the exponential function e^x can be represented as a combination of cosine and sine functions.
The exponential function e^x is a mathematical constant that appears in many areas of mathematics and science. When the exponent is imaginary, as in e^i(x), it represents a rotation in the complex plane. This is why e^i(x) is equal to cos(x) + isin(x), as it combines the real and imaginary components of the rotation.
Euler's formula has many practical applications, including in electrical engineering, quantum mechanics, and signal processing. One example is in the analysis of AC circuits, where the use of complex numbers, including e^i(x), simplifies calculations and allows for more efficient solutions.
Yes, there are several proofs for Euler's formula, including using Taylor series, differential equations, and geometric interpretations. However, the most common and elegant proof is using the properties of complex numbers, specifically their relationship to the polar form and trigonometric functions.
One way to remember Euler's formula is by visualizing the unit circle in the complex plane. The cosine and sine terms represent the x and y coordinates of a point on the circle, and the exponential term represents the angle of rotation. Another way is to remember the mnemonic "Euler's identity: e to the i π is minus 1."
