Can someone clarify some things for me?
  • Thread starter matt@USA
In summary, the conversation is discussing the difficulty of determining variables in 2D equations and the use of subscripts to indicate different components. V is the velocity of the object at a specific time, while V0 is the initial velocity. In an example scenario, V represents the velocity at a given time, while V0 represents the initial velocity. The formula V2 = Vo2 + 2as is recommended for calculating the final velocity in certain situations.
matt@USA
25
I don't know if I am just looking too much into the problems or what, but I am having a very hard time determining what is what in the problems. I am not confident on what I pick as Vnaught, V, x, y, etc ... Will someone please help?
I will tell you how I determine it, and you can correct me.
x=where it lies on the x axis?
y=where it lies on the y axis? ... Both of these are determined by me? Correct?
So is V the velocity of the object? And what is Vnaught?
These are all pertaining to 2D equations.
Naught is usually the initial value of something. If you have a position graph then you could say that x naught is the starting position of the object. You see subscripts used a great deal. i usually denotes an initial value as well, f usually means the final value. Aside from that everything else is pretty descriptive. When you are dealing with 2+d problems, you might see subscripts of x and y to let you know which component it is. Say you have a vector r, they might say that [itex]a_{rx}[/itex] is the acceleration of the x component of the r vector and so on.
Yes, x and y are positions, measured along their respective coordinate axes.
v is velocity. In general it varies with time (i.e., pick a time t, and you'll get a specific value for v).
v0 is initial velocity (i.e. velocity at t = 0).
So what is V?
matt@USA said:
So what is V?
In the context you have provided, V would be the velocity at the time to are dealing with.
Vo is the initial velocity. V is the velocity later.
eg: you might want to know "if a stone is thrown vertically down from the top of a 30m tower with a velocity of 2 ms-1, how fast will it be traveling just before it hits the ground -[take g=10].
everything is happening downwards, so let down be positive.
Vo = 2.0
a = 10
x = 30
V = ??
Best formula to use would be
V2 = Vo2 + 2as
V2 = 4 + 2x10x30 = 604
so V = 24.6
FAQ: Can someone clarify some things for me?
1. What does it mean to clarify something?
To clarify something means to make it clear or understandable. It involves providing additional information or explanations to improve understanding.
2. Why is it important to clarify things?
Clarifying things is important because it helps prevent misunderstandings and confusion. It ensures that everyone has a clear understanding of the topic or issue at hand.
3. How can someone effectively clarify things?
To effectively clarify things, one should use clear and concise language, provide examples or illustrations, and actively listen to any questions or feedback. Visual aids or diagrams can also be helpful in clarifying complex concepts.
4. When should someone ask for clarification?
It is important to ask for clarification when something is unclear or confusing. This can be during a conversation, meeting, or when reading written materials.
5. What are some common barriers to effective clarification?
Some common barriers to effective clarification include language barriers, different levels of knowledge or understanding, and cultural or personal biases. It is important to be aware of these barriers and actively work to overcome them when trying to clarify things.
