Can someone clear up the implications of Planck units once and for all?
In summary: What's the deal with this "discrete spacetime" thing? I don't understand how that even makes sense (in my mind, nature only makes sense if it's continuous even if there are aspects to it that are discrete such as quantization). Even if we say that within quantum mechanics, it doesn't make much sense for us to discuss anything sub-Planck scale, that doesn't mean there isn't something underneath the quantum mechanics or that things aren't still continuous.Discrete spacetime is the idea that spacetime is made up of tiny pieces that are separate from one another, rather than being a continuous space. It's speculation at this point, but some people believe that
SeventhSigma
257
Time and time again I always hear people say that Planck Lengths are the smallest units of meaningful distance.
But I don't think this implies nothing can be smaller than this or that spacetime is discrete, correct? It just means talking about anything smaller than this would be like talking about, say, half-pixels. It's meaningless, but it doesn't prevent some deeper framework from existing.
Would this be a correct way to phrase it?
There is nothing special about Planck units. Nothing. They don't represent any sort of "pixel" size. They are just units.
Well, it's potentially more than that, which is why someone (I think other than Planck) gave it the name "Planck length". It's a distance unit that can be made up of G, c and h, and it's an extremely small distance, so there is some speculation (and, I think in some cases, more than speculation) that it may represent a quantum unit of space, defining say the dimensional scale of a string in string theory.
i wouldn't say that there is nothing special about Planck units.
i wouldn't say that we have a working theory for why the Planck length must be the smallest length nor the Planck time is the smallest time. for sure, the Planck mass is neither the smallest nor largest mass.
but the Planck length is so small, and the Planck time is so small, that it seems like they could be close to a differential length or time for all practical purposes.
expressing equations of physical law in terms of Planck units (or better yet, rationalized Planck units where [itex] 4 \pi G = 1 [/itex]) ends up removing scaling factors between quantities that are identical except for the scale factor. like equating E-field and flux density or (more popularly) mass and energy or time and length.
anyway, if one were to set up a system of cellular automata with cells as big as the (rationalized) Planck length and time discretized to the Planck time (the sampling frequency of reality would be up there around 1043 Hz), then the discrete equations of physical law (derived from the continuous-time equations using Euler's forward differences) have no contrived scaling factors that Nature has to pull out of her butt to convert one quantity (like flux density) to another (like E field).
No. The Planck length is not some sort of pixel size. I don't know why people keep saying this.
It is true that around the Planck length, quantum gravity effects become important. But around might be tens or hundreds of times larger.
Would you say the Planck cosntant is just a units conversion constant?
Yes; they're just units. There's nothing more (or less) special than using feet or inches.
That's what I was suspecting -- I just see all too often people trying to argue that irrational numbers don't exist because Planck lengths imply a discrete spacetime
Irrational numbers exist because we define them to exist within the realm of mathematics, regardless of whether or not spacetime is discrete. It seems probable that spacetime is discrete, with a quantum length scale on the order of the Planck length and a time scale on the order of the Planck time, so ultimately it would not make sense (for example) to carry around significant figures of ∏ beyond what is required to measure or calculate distances to a precision better than a Planck length.
See, that's exactly why I made this thread, though.
Well, it doesn't really make sense to me that light appears to propagate at the same speed regardless of my own speed, or that it would seem to me to take an infinitesimal amount of time to travel to a star in the Andromeda galaxy, but that's how reality appears to be. Space and time may well be (probably are) "foamy" at extremely small scales that we cannot directly access.
Jacob Beckenstein discovered that there is a "pixel" size (not that I like that term) associated with Planck units which clearly implies a discreteness:
adding one bit of information will increase the horizon of any black hole by one
Planck unit of area, or one square Planmck unit. Somehow, hidden in the principles of quantum mechanics and the General Theory of Relativity there is a mysterious connection
between individible bits of information and Planck sized bits of area.
so says Leonard Susskind, THE BLACK HOLE WAR, page 154
(In fact, he has the essential mathematics and steps Beckenstein used outlined from p 150-154...)
Relativists may not like to think about spacetime as discrete because it appears to conflict
with Einsteins relativity...however that apparent conflict might be an illusion:
http://arxiv.org/abs/1010.4354
“The equivalence of continuous and discrete information, which is of key importance in information theory, is established by Shannon sampling theory: of any bandlimited signal it suffices to record discrete samples to be able to perfectly reconstruct it everywhere, if the samples are taken at a rate of at least twice the bandlimit. It is known that physical fields on generic curved spaces obey a sampling theorem if they possesses an ultraviolet cutoff.”
and
http://arxiv.org/abs/0708.0062
On Information Theory, Spectral Geometry and Quantum Gravity
Achim Kempf, Robert Martin
4 pages
(Submitted on 1 Aug 2007)
We show that there exists a deep link between the two disciplines of information theory and spectral geometry.
And I kept this for my own notes from another thread here:
http://pirsa.org/09090005/
Spacetime can be simultaneously discrete and continuous, in the same way that information can.
In this thread
https://www.physicsforums.com/showthread.php?t=391989
"argument for the discreteness of spacetime",
Ben Crowell posted this question...
The following is a paraphrase of an argument for the discreteness of spacetime, made by Smolin in his popular-level book Three Roads to Quantum Gravity. The Bekenstein bound says there's a limit on how much information can be stored within a given region of space. If spacetime could be described by continuous classical fields with infinitely many degrees of freedom, then there would be no such limit. Therefore spacetime is discrete.
(This is very similar to Susskind's discussion which I referenced above.)
and the subsequent long discussion is very good.
Several years ago I posted something like "Are we analog or digital?" and got some good discussion, but at that time I posted maybe a dozen or so reasons suggesting spacetime is discrete..we are DIGITAL..and was leaning that way.
Maybe "continuous" and "discrete" are two sides of the same coin, analogous to wave-particle duality.
PS: there are many other discussions on "discreteness" in these forums.
Nice Post Naty1, we do not have a good understanding of this yet.
So, sorry OP (Original Poster) but no one can clear it up (just yet).
For an interesting essay on Planck's own views see:
http://books.google.com/books?id=S3FOuMYHcqIC&lpg=PP1&pg=PA21#v=onepage&q&f=false
Dimensionless universal constants could now be constructed that necessarily would have the same value for all physicists, human or not, irrespective of their systems of measurement.
it just makes for elegant mathematical relationships (when these continuous-time, continuous-space differential equations are discretized using Euler's forward method). and the Planck length and Planck time are so small (so far beyond any precision of measurement) that no one would know the difference.
Here is another paper of possible interest:
(This is the same Lee "Smolin" Ben Crowell referenced above. )
Holography in a quantum spacetime
Fotini Markopoulou∗and Lee Smolin†
Center for Gravitational Physics and Geometry
Department of Physics
The Pennsylvania State University
http://arxiv.org/PS_cache/hep-th/pdf/9910/9910146v1.pdf
In this paper, we present a framework for a Planck-scale, cosmological, background independent theory which is holographic in a sense appropriate to a quantum spacetime.
This is motivated by the fact that the formulations of the holographic principle
given to date[1]-[6] are confined to the semiclassical regime. At the same time, results of several approaches to quantum gravity indicate that the description of spacetime
based on smooth manifolds can provide only an approximate description
[7]-[12]. If it is true, the holographic principle ought then to be more than a conjecture about the classical and semiclassical theory. Rather, it should be an important part of the
framework of a Planck-scale, background independent quantum theory.
Of course irrational numbers exist, even if there is "pixels" of space. The very definition of the plank length implies this.
If you look in the Planck length equation above, in there is pi (in h-bar) and a square root. Both of which produce irrational numbers. Therefore, irrational numbers must really exist if the plank length has any meaning.
Related to Can someone clear up the implications of Planck units once and for all?
1. What are Planck units?
Planck units are a set of natural units that are derived from fundamental physical constants, namely the speed of light, the gravitational constant, and the reduced Planck constant. These units were first introduced by German physicist Max Planck in the early 1900s and are used in theoretical physics to provide a consistent system of measurement at the most fundamental level.
2. What are the implications of Planck units?
The implications of Planck units are significant as they provide a way to understand and describe the fundamental properties of the universe, such as space, time, mass, and energy. They also have implications for theories such as quantum mechanics and general relativity, as they allow for a more unified understanding of these concepts.
3. How do Planck units relate to the concept of the Planck scale?
The Planck scale is the scale at which quantum effects become important in understanding the behavior of the universe. Planck units, being derived from fundamental constants, are used to measure quantities at this scale and provide a way to study and understand the fundamental nature of the universe.
4. Can Planck units be used to measure everyday objects?
No, Planck units are extremely small and are typically used to measure objects and phenomena at the most fundamental level. They are not practical for measuring everyday objects, as their values are far too small to be useful in everyday life.
5. Are there any limitations to the use of Planck units?
While Planck units are useful for understanding and describing the fundamental properties of the universe, they have limitations. One limitation is that they are based on our current understanding of physics, which may change as new theories and discoveries are made. Additionally, they may not be applicable in extreme environments, such as near black holes or during the early stages of the universe.
  • Other Physics Topics
  • Quantum Physics
  • Beyond the Standard Models
  • Quantum Physics
