- #36
russ_watters
Mentor
- 23,386
- 10,701
This is a wording issue: before they are brought back together and the situation is symmetrical, neither can be said to be running faster or slower. Once they are brought back together, you can say one went faster/slower. But that's not the issue here: the issue is what that implies about the laws of physics. The fact that the outcome is not the same does not imply the laws of physics aren't consistent, because the conditions of each twin's journey aren't the same. More on that in a sec...NeutronStar said:Yes, I disagree with your statement; "...there is no objective truth about whose clocks are really running slower".
I think it's quite obvious when the twins get back together that the younger twin was the one whose clock ran slower. There can be no denial of this since that is the twin that is younger upon return. What else would cause this effect if it wasn't objectively true? Really.
Lemme try a different tack here: it seems you agree with everything except the conclusion. All of it is here:
First off, you seem hung-up on the part about acceleration (yet you say frame of reference is unimportant?) - the acceleration is what puts them in different frames.The twin that ages less may have undergone an acceleration, however, his or her clock continues to run more slowly relative to the non-accelerated sibling even after the acceleration has ceased. Therefore, the twin who has undergone a change in an inertial frame has also undergone a change in his or her fundamental laws of physics
You also seem hung-up on the outcome (and this is probably more important): you're saying that the fact that the clocks show different times means the laws of physics are different. But that's wrong. Lemme give an example: you have two identical rocks. You throw one and your little brother throws the other. But they don't move the same distance. Why not? The rocks are identical, the laws of physics are identical - why wouldn't they go the same distance? Well, you're stronger than your little brother - you pushed harder! So too with the twins paradox: the laws of physics are the same, its just that you're doing different things to the two clocks: one is being accelerated, the other isn't. What's more, after the rocks leave your hand, they are no longer accelerating - shouldn't they then go the same distance (just like the twins who are not accelerating...)? No, the acceleration is what makes their frames different and what makes them travel different distances.
This seems self-evident, but perhaps its a symptom of another issue: what you are saying implies the desire for Time to be an absolute like C. If the laws of physics said time is abslute, then yes, certainly there'd be a contradction. But the laws of physics don't say that.
