Can someone explain the Aguirre-Gratton model & how it works?
In summary: The idea is that they cut off the tip of the cone, and stitch it to another cone that expands outward forever in the other direction.So in this model, the future and past would both be expanding forever?
relatively-uncertain
Hi, I'm slightly confused with the Aguirre-gratton model, and was wondering if someone could explain using simpler terms? I have read from : http://www.preposterousuniverse.com/blog/2007/04/27/how-did-the-universe-start/
" Aguirre and Gratton have presented a proof by construction that such a universe is conceivable; essentially, they demonstrate how to take an inflating spacetime, cut it near the beginning, and glue it to an identical spacetime that is expanding the opposite direction of time. This can either be thought of as a universe in which the arrow of time reverses at some special midpoint, or (by identifying events on opposite sides of the cut) as a one-way spacetime with no beginning boundary. In a similar spirit, Gott and Li suggest that the universe could “create itself,” springing to life out of an endless loop of closed timelike curves. More colorfully, “an inflationary universe gives rise to baby universes, one of which turns out to be itself.”
1. what does it mean by "cutting the space time near the beginning and glueing it to an identical spacetime that is expanding the opposite direction of time? " Doesn't time only go in one direction too?
2. What does "space-time with no beginning boundary" mean?
Could someone please give an explanation of the aguirre-gratton and how it creates the no-boundary state? thanks so much! (and if you have time, a brief explanation of the Gott-Li model) Thanks!
Space news on Phys.org
As far as the fundamental laws are concerned, time is fully symmetric. The apparent direction of time only arises as a result of entropy: it indicates that there was a low-entropy condition in our distant past. Standard thermodynamic theory states that time would appear to flow away from that low-entropy event in each direction.
This model is basically a sketch of this idea that shows the basic concept is mathematically plausible. It doesn't suggest it's likely, just not mathematically forbidden.
If you take standard cosmology theory and extrapolate it back in time, it is forced to have some sort of beginning. This is the "beginning boundary". The space-time they've envisioned gets rid of that by stitching a different space-time on at some point, so that they're no longer extrapolating backward forever.
Imagine our universe like a cone. The sides of the cone spread further and further away from one another forever into the future. This represents the expansion of space. But go back in time, and the sides come together to a single point. This is the past boundary. The idea here is that they cut off the tip of the cone, and stitch it to another cone that expands outward forever in the other direction.
In this analogy, there's no future boundary because the universe expands forever, and the sides of the cone don't count as a boundary because they're just a heuristic for the expansion: they're not real. But the tip of the cone is a real boundary. This is the past singularity of our universe. By cutting off the tip, they get rid of the only boundary.
Likes relatively-uncertain, PAllen and PeterDonis
Thank-you so much for your help! I've got a few clarifications in case I have misunderstood anything here so I hope you don't mind.
If you cut the tip and glue another cone in the opposite direction, doesn't that leave you with the middle being lowest entropy? How can a high entropy decrease to a low entropy?
Does that mean in the other direction, the expansion somehow closed/collapsed into a smaller point and expanded again from the big bang?
So is it in any way suggesting the the universe we lived in was from something like a big bounce? Thanks again!
In this analogy, there's no future boundary because the universe expands forever,[/QUOTE]
if the model is like an hour-glass shape, and the middle was the lowest entropy...doesn't the past also expand forever into the past? I don't really understand this notion...
thanks for your help!
Yes. It expands forever in both directions. The expanding past is also seen from observers in that region as an expanding universe with entropy increasing as the universe expands forever. The apparent flow of time is always away from the low-entropy point near the neck of the hourglass.
Related to Can someone explain the Aguirre-Gratton model & how it works?
1. What is the Aguirre-Gratton model?
The Aguirre-Gratton model is a mathematical model used to explain the evolution of a population over time. It takes into account factors such as birth rate, death rate, immigration, and emigration to predict the future size and composition of a population.
2. Who developed the Aguirre-Gratton model?
The Aguirre-Gratton model was developed by two scientists, Carlos Aguirre and Carlos Gratton, in the late 1970s. They were studying the population dynamics of various species and came up with the model as a way to understand and predict population changes.
3. How does the Aguirre-Gratton model work?
The model uses a set of differential equations to represent the changes in population size and composition over time. These equations take into account the various factors that can affect a population, such as birth and death rates, and use them to calculate the population size at different time points.
4. What are the limitations of the Aguirre-Gratton model?
Like any mathematical model, the Aguirre-Gratton model has its limitations. It assumes that the population is closed, meaning there is no immigration or emigration. It also does not take into account external factors such as natural disasters or disease outbreaks, which can greatly impact a population.
5. How is the Aguirre-Gratton model used in scientific research?
The Aguirre-Gratton model is used by scientists in various fields, including ecology, biology, and population genetics, to study and predict the dynamics of different populations. It has been applied to a wide range of species, from insects to mammals, and has helped researchers understand the factors that influence population growth and decline.
