Can someone explain this equation?
  • Thread starter lionely
  • Tags
    Explain
In summary, the equation F=(mg/sin θ)+K was used to plot a graph of F against 1/sin θ. By rearranging the equation to y=mx+c, where y=F and x=1/sin θ, the slope of the graph was determined to be equal to mg. Using this information, along with the y-intercept (K=0), the equation was solved for the unknown variables, resulting in μ=mg and c=0. This technique is commonly used to verify theoretical predictions.
lionely
576
F= (mg/sin θ) + K
I don't understand how this equation came about. I have a physics practical to finish and I need to use this to finish it.
I plotted a graph of F against 1/sin θ
I got a straight line passing through the origin.
So i tried to see if i could get the formula from
y=mx + c
Could someone tell me where mg comes from in this?
Take your equation written at the top - erase the ##F## and put a ##y## in it's place. Erase the ##1/\sin(\theta)## part and put an ##x## there instead. Now compare what you have with the equation ##y=mx+c##.
m=?
c=?
which part of mx+c is the slope of the graph and which the y-intercept?
m is the slope c is the intercept.
but how would mg be the gradient?
from my graph c = 0
and for m I got 1.92, but how is that related to mg?
lionely said:
from my graph c = 0
mg = 1.92
Oh, I'm sorry I still quite fully understand. so Force/sin X is equal to mass x gravity?
You determined that K (=c) = 0. Put that in your original equation.
How about [itex]\ \ F\times\sin(\theta)=mg\ ?[/itex]
How can it be anything else?
You know from the theoretical relation that:
F=mg/sin(θ)+K
(Presumably you started with Fsin(θ)=mg+Ksin(θ) or something - then rearranged it so you can get a graph that is a straight line.)
Since x=1/sin(θ) and y=F, this is the same as:
y = mgx + K
This has to be the same as y=μx+c
(using μ for the gradient because m is already taken for "mass".)
So what do μ and c have to be to make these two lines the same?
hint - if the lines are the same then: mgx + K = μx+c
Note: starting from Fsin(θ)=mg+Ksin(θ) ... you could have plotted y=Fsin(θ) vs x=Ksin(θ): then the slope would have been 1 and the y-intercept would have been mg. But it is best practice to find the thing you want in the gradient of something.
mu would have to be 1.92 and c 0.
No - using only mgx+K = μx+c.
mgx+ k = μx+c
1.92/sin + 0 = 1.92x + 0
right?
You did one step too many.
If Ωx+ζ=μx+c
then μ=Ω
and c=ζ
If <carrot>x+<banana>=μx+c
then μ=<carrot>
and c=<banana>
If (a+b)x+qwerty=μx+c
then μ=(a+b)
and c=qwerty
If (a/b)x+A=μx+c
then μ=(a/b)
and c=A
If mgx+K=μx+c
then μ=
and c=
μ= mg
c=K
Great - in relation to your question... "how is mg the slope":
You have a theory that predicts that if you plot y=F vs x=1/sin(θ) you will get a line whose slope is mg - namely: y=(mg)x+K. You did the experiment and came up with a line ... the slope of which you found to be 1.92units (is that correct? what are the units?): namely: y=(1.92)x+0.
Therefore:
1. The theory has successfully predicted the line.
2. If the theory is correct then (mg)x+K=(1.92)x+0 ... which means that mg=?, K=?
This is a common technique: you rearrange the theory so that some experiment - if the theory is right - will produces a line. Then you measure the line and compare with the theoretical prediction.
1.92 Newtons
Oh I think I understand now.
Great. 1.92N suggests to me a mass something like 200g.
Has your question been answered?
Yes! Cause when I worked out the mass I got .20kg. The mass would be equal to
m= gradient/9.81 right?
Well thank you for the help, I finished everything.
That would be all correct - well done.
FAQ: Can someone explain this equation?
What does this equation represent?
This equation represents a mathematical relationship between different variables. It can be used to solve problems or make predictions.
How do I read this equation?
To read this equation, start from the left side and work your way to the right. Each symbol or number has a specific meaning and contributes to the overall relationship being represented.
What do the symbols and numbers in the equation mean?
The symbols and numbers in the equation are known as variables and constants. Variables represent values that can change, while constants have fixed values. Each symbol and number has a specific role in the equation and contributes to the overall solution.
How do I solve this equation?
To solve this equation, you need to follow the rules of algebra and use techniques like substitution, factoring, and simplifying. It is also helpful to have a good understanding of the meaning behind each symbol and number in the equation.
Can someone explain step by step how to solve this equation?
Yes, someone can explain the steps to solve this equation. It is helpful to have a basic understanding of algebra and the meaning behind each symbol and number in the equation. From there, the equation can be broken down and solved step by step using different techniques and strategies.
