Trollfaz
- 137
- 14
Can someone explain a flop transition to me in laymen terms? And what consequences does it have on the universe? Thanks
Throughout 1992, Greene and Plesser attempted to gather mathematical evidence of mirror-perspective Calabi-Yau spaces. Greene decided to spend the fall of 1992 at the Institute for Advanced Study with mathematician David Morrison and Greene’s Oxford classmate Paul Aspinwall. Over the course of that fall, Morrison, Aspinwell, and Greene proved mathematically that flop transitions did not destroy mirror symmetry. Around the same time, Witten had also established, by different methods, that flop transitions occur in string theory. Witten went beyond Greene and his coresearchers’ findings to show why flop transitions do not trigger cosmic catastrophe: when a tear occurs, an adjacent string encircles and reconstitutes it. Together, Greene, Morrison, Aspinwall, and Witten mathematically demonstrated the existence of topology-changing transitions (a more technical name for flop transitions). These findings, Greene predicts, will lead to a revolutionary revision of Einstein’s general relativity.
PAllen said:The only flop transition I know of is a feature of string theory, in which case this the wrong forum section to discuss it. It should be in the beyond the standard model subforum.
jedishrfu said:https://en.wikipedia.org/wiki/Flop-transition
Basically, the universe shrinks and the spacetime tears and gets repaired with different properties. What those changes are is harder to describe? After the tear, perhaps you would perceive time traveling backwards but we don't know.
https://www.sparknotes.com/lit/elegant universe/section4/page/3/
A flop transition is a term used in film and video editing to describe a specific type of transition between two shots. It involves one shot fading out while another shot fades in, creating a smooth and seamless change between the two shots.
A flop transition differs from other types of transitions, such as cuts or wipes, in that it involves a gradual fade between shots rather than an abrupt change. This can create a more subtle and fluid transition that is less jarring for the viewer.
Flop transitions are often used to indicate a passage of time or a change in location or perspective. They can also be used to create a dreamy or nostalgic effect in a film or video.
A flop transition is created using video editing software. The editor will typically overlap the two shots and adjust the opacity of each shot to create the desired fade effect. The duration of the transition can also be adjusted to control the speed of the fade.
Anyone with access to video editing software can use a flop transition. It may take some practice and experimentation to achieve the desired effect, but it is a commonly used and accessible transition in the world of film and video editing.
