Can someone explain to me Locality in field theory?
In summary, in field theory, the concept of locality refers to the conditions of causality and the ability to write the action as a local integral. These conditions work together to ensure Lorentz invariance and prevent classical theories from showing action-at-a-distance. Though nonlocal actions do not appear in the standard model, they may have applications in other areas of physics, such as effective field theories or condensed matter.
alemsalem
175
Can someone explain to me "Locality" in field theory?
I know that two fields have to commute at space-like separations so that observations don't affect each other at these separation.
what about the thing where the Lagrangian can't couple fields at different locations and time, is it so that we get a normal (local) differential equation and not one that involves the field at different coordinates.
any other information would be great,, Thanks.
There are a few terms and ideas that are related here, but not quite the same. You mention two separate things; these two conditions work together to guarantee such things as the Lorentz invariance of the S-matrix.
Here's the first: I'd call it causality. It basically makes sure that time-ordering is unambiguous and Lorentz invariant. There is no invariant definition of before and after for spacelike separated events, so we make it so that order doesn't matter: operators must commute at spacelike separation.
This is what's normally called locality (in QFT): it's the condition that the action can be written as
[tex]S = \int d^4 x \mathsc{L}(x)[/tex]
and, for example, there can be no terms like
[tex]\int d^4 x d^4 y \phi(x)\phi(y).[/tex]
This isn't actually required to preserve Lorentz invariance, but it's a very convenient way to guarantee it, and is almost always assumed to be true*. As you say, this makes the classical equations of motion into PDEs, which is enough to prevent the classical theory showing action-at-a-distance.
These two things together ensure Lorentz invariance. Weinberg vol. 1 has more details towards the beginning (in the scattering bit I think).
Locality in a broader sense is a bit of a sensitive subject in quantum theories and not an area a know a huge amount about, but a search for such things as entanglement, the EPR paradox and Bell's inequality will give a good overview.
*Nonlocal actions don't appear in standard model physics. But I've seen them show up in effective field theories, and there are probably lots more applications for them in beyond SM physics, condensed matter or other areas.
FAQ: Can someone explain to me Locality in field theory?
What is locality in field theory?
Locality in field theory refers to the idea that the value of a field at a given point in space and time is only affected by the values of other fields at nearby points in space and time. This means that there is no instantaneous action at a distance, and the interactions between fields are mediated by the exchange of particles.
Why is locality important in field theory?
Locality is important in field theory because it is a fundamental principle that allows us to make predictions and calculations about the behavior of physical systems. It also allows for the construction of consistent and mathematically well-defined theories.
How does locality relate to Einstein's theory of relativity?
Locality is closely related to Einstein's theory of relativity, specifically the principle of local causality. This principle states that any physical effect can only be influenced by events in its past light cone, meaning that information cannot travel faster than the speed of light. This is consistent with the idea of locality in field theory.
Are there any violations of locality in field theory?
There have been proposed theories that suggest possible violations of locality, such as non-local hidden variable theories. However, these theories are not widely accepted and have not been supported by experimental evidence.
How does locality impact the concept of quantum entanglement?
Locality plays a crucial role in the study of quantum entanglement. According to the principles of quantum mechanics, entangled particles can exhibit correlations that are non-local, meaning that the state of one particle can affect the state of another even when they are separated by large distances. However, these correlations cannot be used to transmit information faster than the speed of light, preserving the principle of locality.
