Can someone give me a hand with large root here
In summary, the conversation discusses the process of simplifying and removing a large square root from a quotient. The expert explains that the square root can be eliminated by squaring the entire quotient and that the decision to keep or remove the root is a matter of preference.
lioric
323
i get the differentiation
the halves cancel the 2 the h bar cancels the h bar square
and to get rid of the root in the denominator the entire thing is squared
But I cannot understand where the huge square root came from at the end where I circled.
Can someone help me here
##a = \sqrt{a^2}## for positive ##a## and ##\frac{a}{\sqrt{b}} = \frac{\sqrt{a^2}}{\sqrt{b}} = \sqrt{\frac{a^2}{b}}##
Ok i understand what you are saying.
But what if we square the entire thing
And the root and the square gets canceled like this
Exactly. If
\left( \frac{pc^2}{\sqrt{p^2c^2 + m^2 c^4}} \right)^2 = \frac{p^2c^4}{p^2c^2 + m^2 c^4}
then
\frac{pc^2}{\sqrt{p^2c^2 + m^2 c^4}} = \sqrt{\frac{p^2c^4}{p^2c^2 + m^2 c^4}}
which is what you have in original text.
You don't square the entire quotient. Set ##a=pc^2## and ##b = p^2c^2+p^2m^4##.
DrClaude said:
Exactly. If
then
Ok if one can get rid of the huge square root why keep it.
I mean as you said in the first part, why is the solution choosing to keep the huge root if we can choose to remove it
It is a question of preference. Some things can be easier to see if all the terms are on the same footing (e.g., all under the square root), but where to stop simplifying can be a matter of taste.
Thank you very much
I'll try it both ways once I get a hang of things
Thank you very very much
FAQ: Can someone give me a hand with large root here
What do you mean by "large root"?
By "large root", I am referring to a plant's root system that is significantly bigger in size than average. This could be due to various factors such as the type of plant, the soil conditions, and the age of the plant.
Why would someone need help with a large root?
Large roots can be difficult to handle and remove, especially if they are in a confined space or near important structures such as pipes or foundations. Therefore, someone may need assistance in safely and effectively removing the root without causing damage.
How can I give someone a hand with a large root?
First, you should assess the situation and determine the best course of action. This may involve using specialized tools, such as a root cutter or excavator, to carefully remove the root. It is important to follow proper safety precautions and to work slowly and carefully to avoid any accidents.
What are the risks of removing a large root?
Removing a large root can be dangerous if not done properly. There is a risk of injury to yourself or others, as well as potential damage to surrounding structures or plants. It is important to have a plan in place and to follow proper techniques when removing a large root.
Can I transplant a large root to another location?
In some cases, it may be possible to transplant a large root to another location. However, this should only be done by a trained professional as it can be risky and may not always be successful. It is important to consider factors such as the health of the root, the soil conditions, and the compatibility of the new location before attempting to transplant a large root.
