Can someone help a newbie, electric forces
In summary, the force of repulsion between two charges is decreased by a factor of four when the distance between the charges is increased by a factor of 5.
DSM4Life
Ok this is the question in textbook i can't figure out.
"The force of repulsion that two like charges exert on each other is 3.5N. What will the force be of the distance between the charges is increased to fice times its orginal value ? "
im a physics moron , treat me like one :smile:
ok i understand that two like charges will repluse.
In this case its at 3.5N. So i was thinking that if the force of it was at 3.5N and the distance was increased by 5x then just multiply 3.5N x 5 = 17.5 which when i check in back off the book is wrong. Can you help explain this to me so i can understand it ? The answer the book has is 0.14N
Coulomb's law
Welcome to PF!
You'll need to understand Coulomb's law, which describes the force between two charges:
[tex]F = k\frac{q_1q_2}{r^2}[/tex]
Note that the force decreases as the charges get further apart, but it's proportional to 1 over the square of the distance. For example: if the distance is doubled, the force is 1/2 x 1/2 = 1/4 as much--four times smaller.
Doc Al said:
Welcome to PF!
see i was looking at that in my book. The thing that was throwing me off is that i thought i needed another q value.
I understand its the constant K then q1 point and q2 divided by sq distance but i didnt know where the second value was. Still little confused.
F = (8.99x10^9) |q1||q2|
r^2
umm what is the distance and points :confused:
You are given everything you need to answer the question. You don't need to know the charges (they don't change) and you don't need to know the actual distance--just by what factor it increases. If you understand what Coulomb's law is telling you--you can solve this problem just by ratios.
As I said before: if the distance doubles, then the force decreases by a factor of four. Right? And if you know what the force was to start with, then you can find out what it ends up being. Right?
Now in your problem the distance increases by a factor of 5. So by what factor does the force decrease? Figure out that new force.
the new force would be i/25 th of the original force according to coloumbs law f=kq1q2/r^2
Here's a way to think about what Doc Al said:
Given [tex]F = k\frac{q_1q_2}{r^2}[/tex] and [tex]F=3.5\ N[/tex],
you want [tex]F_{new}[/tex] when [tex]r_{new}=5r_{old}[/tex].
Observe
[tex]
\begin{align*}
F_{new}
&= k_{new}\frac{q_1_{new}q_2_{new}}{r_{new}^2} && \text{Coulomb}\\
&= (k_{old})\frac{(q_1_{old})(q_2_{old})}{(\textcolor{red}{5}r_{old})^2} && \text{new in terms of old}\\
&= \frac{1}{\textcolor{red}{5}^2}(k_{old})\frac{(q_1_{old})(q_2_{old})}{(r_{old})^2} && \text{algebra}\\
&= \frac{1}{\textcolor{red}{5}^2} F_{old}&& \text{Coulomb}\\
\end{align *}
[/tex]
Note the ratio [tex]\frac{ F_{new} }{ F_{old} } = \frac{1}{5^2} [/tex].
FAQ: Can someone help a newbie, electric forces
1. What are electric forces?
Electric forces are interactions between charged particles, such as electrons and protons. These forces can either attract or repel each other, depending on the charges of the particles.
2. How do electric forces work?
Electric forces are caused by the exchange of virtual particles called photons between charged particles. This exchange creates an electric field that exerts a force on other charged particles.
3. What is the formula for calculating electric forces?
The formula for calculating electric forces is F = k(q1q2)/r^2, where F is the force, k is the Coulomb's constant, q1 and q2 are the charges of the two particles, and r is the distance between them.
4. What is the difference between electric forces and magnetic forces?
Electric forces are caused by the interaction of charged particles, while magnetic forces are caused by the interaction of moving charged particles. In addition, electric forces can either attract or repel, while magnetic forces only attract.
5. How are electric forces used in everyday life?
Electric forces are used in a variety of everyday devices, such as electric motors, generators, and batteries. They are also used in household appliances, electronics, and power grids to provide electricity for our daily needs.
