Can someone me build the differential equation for this word problem?
In summary, the pond would end up containing 1,000 mg of HgCl2 after an hour, 10,000 mg of HgCl2 after a day, and 100,000 mg of HgCl2 if the process were to go on indefinitely.
skyturnred
118
A tailing pond at a mine contains a million liters of water and 10 kg of the very toxic substance mercuric chloride (HgCl2), mixed evenly throughout the water in the pond. Water from the mining operation flows into the tailing pond at a rate of 10 liters per second, and each liter of water is contaminated with 1 mg of HgCl2, which mixes instantly into the pond water upon arrival. Unfortunately, the mining company does absolutely nothing to remove the mercury from the pond water, and allows it to exit the pond unfiltered, at the same rate of 10 L/sec. How much HgCl2 is found in a liter of pond water after this process continues for (a) an hour (b) a day (c) If the process were to go on indefinitely, how much HgCl2 would the pond end up containing?
I know how to do differential equations if they are given, but I cannot seem to construct one from the text above. That is the extent of my attempt at a solution, because I don't even know where to start.
Thanks in advance!
hi skyturnred! :wink:
the volume of liquid is fixed, so call the weight of HgCl2 "m"
there are two things contributing to dm/dt …
the amount entering, and the amount leaving …
so write out dm/dt for each, and add
what do you get? :smile:
OK, that makes much more sense. I was trying to somehow incorporate the volume of the water.
So the amount going in is 10 kg / s. Do dy/dt going in is 10. But I'm confused about the amount going out. The initial amount leaving would be dy/dt=-0.0001, but this value obviously changes over time. So I have to somehow add a time variable in there. But I have no idea how to do this.
Thanks by the way, you have already cleared it up a lot.
noooo
… I'm confused about the amount going out. The initial amount leaving would be dy/dt=-0.0001, but this value obviously changes over time. So I have to somehow add a time variable in there.
that would be difficult!
no, the "word problem" doesn't give it as a function of time, does it?
it's a function of how much HgCl2 is still in the water! :wink:
OK, hate to be hard headed but that just makes it more confusing again. I don't quite understand how this question could possibly be done without using a function of time.
The amount changing initially is + one mg (or 0.000001 kg) per liter, but there are ten liters going in every second.
a differential equation may have a solution which is a function of time, but that doesn't mean the equation itself contains a function of time
eg x'' = -k2x has no function of t, but its solutions are x = Acoskt + Bsinkt :wink:
Related to Can someone me build the differential equation for this word problem?
1. What is a differential equation?
A differential equation is a mathematical equation that describes how a quantity changes over time, based on the rate at which that quantity is changing. It involves derivatives, or rates of change, and is typically used to model physical systems or phenomena.
2. How do I know if a word problem can be solved using a differential equation?
If a word problem involves a quantity that is changing over time and the rate of change can be described by a mathematical expression, it can likely be solved using a differential equation. Additionally, many real-world problems can be approximated by differential equations, so it's always worth considering as a potential solution.
3. Can anyone build a differential equation for a word problem?
While anyone with a basic understanding of calculus and physics can attempt to build a differential equation, it requires a certain level of mathematical skill and knowledge to construct an accurate and meaningful equation. It's best to consult with a mathematician or physicist for help with building a differential equation.
4. What are the steps for building a differential equation for a word problem?
The process for building a differential equation involves first identifying the quantities and their rates of change in the word problem, and then setting up an equation that relates these quantities and their derivatives. This equation can then be solved to determine the behavior of the system over time.
5. Can a differential equation be solved analytically or does it require numerical methods?
Some differential equations can be solved analytically, meaning a closed-form solution can be obtained using mathematical techniques. However, more complex or nonlinear equations may require numerical methods, such as approximation or simulation, to find a solution.
12K
