MHB Can squares of any size fit perfectly into a 16.5cm x 14cm rectangle?
  • Thread starter Thread starter TPceebee
    2d
The discussion focuses on fitting squares into a 16.5cm x 14cm rectangle, with size constraints of 0.5cm to 2.5cm. After converting the dimensions to millimeters, the prime factorization reveals that the only common factor is 5. This means that the only size of squares that can perfectly tile the rectangle is 5mm x 5mm, or 0.5cm x 0.5cm. Larger squares, up to 2.5cm, cannot fit without leaving gaps. Thus, complete tessellation is only achievable with the smallest square size.
TPceebee
Hi, I'm a product designer looking for some help.
I need to fit squares into the dimensions of a rectangle. There can be any amount of squares just as long as the squares are complete and their dimensions are complete decimals.
The dimensions are 16.5cm x 14cm. I don't want the squares to be any larger than 2.5cm or any smaller than 0.5cm.
Mathematics news on Phys.org
I would convert the dimensions of the rectangle to mm, so that you have 165 mm X 140 mm. Next, let's look at the prime factorization of both measures:
$$140=2^2\cdot5\cdot7$$
$$165=3\cdot5\cdot11$$
We see that the only common factor is 5, so your only choice (for complete tessellation) is to tile the rectangle with squares 5 mm X 5 mm, or 0.5 cm X 0.5 cm.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
