Can the Algebraic Result of a Dot Product be Applied to Vectors?
  • MHB
  • Thread starter veronica1999
  • Tags
    Vector
In summary, the dot product of a vector u can be represented by both u•u and |u|^2, both of which have the same meaning. However, the difference is that u•u is a dot product while |u| is the magnitude of u. As for the familiar algebraic result that (u − v) • (u − v) = u•u−2u•v+v•v, it does hold for dot products of vectors, as proven in the category "Proof of the geometric interpretation" on the Wiki page provided. This property is discussed in detail on various math sites, including the one linked in this conversation.
veronica1999
61
Could someone please take a look at my attached work?
10. Given a vector u, the familiar absolute-value notation |u| is often used for its magnitude. Thus the expressions u•u and |u|^2 both mean the same thing. What exactly do they mean?11. For any two numbers a and b, the product of a−b times itself is equal to a^2−2ab+b^2. Does this familiar algebraic result hold for dot products of a vector u − v with itself? In other words, is it true that (u − v) • (u − v) = u•u−2u•v+v•v? Justify your conclusion, trying not to express vectors u and v in component form.
  • vector.pdf
Mathematics news on Phys.org
I believe the difference in #10 between u*u and |u|^2 is that u*u is a dot product and |u| is the magnitude of u which is calculated similarly to the Pythagorean Theorem but allowing for more elements. Only using words I would say this shows that the dot product of vector u is equal to the square of the magnitude of vector u.
For #11 see this Wiki page and find the category heading "Proof of the geometric interpretation". This properly is fully derived and explained step by step starting with the Law of Cosines.
I hope this helps. Both of these properties are discussed in detail on many math sites, including the Wikipedia page I linked to in this thread.
Thank you!
FAQ: Can the Algebraic Result of a Dot Product be Applied to Vectors?
What is a simple vector problem?
A simple vector problem involves using vector quantities, such as direction and magnitude, to solve a mathematical problem.
What are vector quantities?
Vector quantities are physical quantities that have both magnitude and direction, such as velocity, force, and displacement.
How are vectors represented?
Vectors are typically represented graphically with arrows, where the length of the arrow represents the magnitude and the direction of the arrow indicates the direction of the vector.
What is the difference between vectors and scalars?
Vectors have both magnitude and direction, while scalars only have magnitude. For example, velocity is a vector quantity because it has both speed and direction, while speed is a scalar quantity because it only has magnitude.
What are some common operations used in vector problems?
Common operations used in vector problems include addition, subtraction, multiplication by a scalar, and finding the dot product or cross product.
