Can the centre of mass do work?
In summary, the conversation discusses the concept of total momentum and energy in a system where two equal masses are moving away from each other at the same speed. It is explained that the centre of mass has no speed and the total energy of the system is stored as internal energy. The possibility of extracting this energy without opening the system is explored, with the conclusion that it can only be done if the collisions are inelastic. However, a more clever solution is proposed involving a cylinder and a piston, where the energy of the moving top can be harvested to remove kinetic energy from the balls inside.
albertrichardf
165
Hello,
Consider two equal masses moving away from each other at the same speed. The total momentum of the system is zero, so the total momentum of the system is zero. Therefore, the centre of mass has no speed.
The total energy in the system is ##mv^2##, due to the kinetic energy of the two masses. The energy of the centre of mass must be stored in some other way, because the kinetic energy of the centre is zero. It would be the "internal energy" of the centre, just like an ideal gas has internal energy due to the kinetic energy of its molecules.
Suppose, now we create an ideal box, one for which all collisions with the inner walls are perfectly elastic. We can take the system we imagined, and place it in the box. The box is then sealed. Inside the box, the masses go back and forth, colliding with the walls of the box, and colliding with each other. However, it is arranged so that the total momentum of the masses at any instant is zero. The box then contains some energy ##mv^2##.
My question is, can we extract that energy and do work with it without ever opening the box? Ideal gasses allow this energy to be detected by increasing the temperature of the box. By placing the box with something at a lower temperature we can extract work. Is there a macroscopic equivalent to that?
Thanks for answering.
Sure. Let the collisions with the wall be inelastic. That is how heat is transferred too.
Thanks for answering. So there is no way of extracting energy, unless the collisions are inelastic?
Correct. That is the definition of an elastic collision.
Edit: note @jbriggs444 has a more clever solution below
That makes sense: since the kinetic energy of a system with solely elastic collisions can't change, you shouldn't be able to extract any energy from it either. Thank for clearing it up.
Suppose that instead of a rigid box, we have one with a fixed bottom, tall fixed sides and a top that is free to slide up and down. i.e. A cylinder and a piston.
Balls inside the cylinder can collide with the top. These collisions are elastic -- total kinetic energy of top plus balls is unchanged. But the top is pushed upward as a result. One could harvest the energy of the moving top. The net effect would be to remove kinetic energy from the balls.
Thanks for the answer. It does make sense that such a system would behave like an ideal gas.
Related to Can the centre of mass do work?
1. Can the centre of mass do work if it is stationary?
Yes, the centre of mass can still do work even if it is stationary. Work is defined as the product of force and displacement, and the centre of mass can experience a displacement even if it is not moving. For example, if a book is placed on a table, the centre of mass of the book is stationary but the table is exerting a normal force on the book, causing a displacement of the book's centre of mass.
2. How does the centre of mass do work?
The centre of mass does work through the application of external forces. When a force acts on an object, it causes a displacement of the object's centre of mass. If the direction of the force is the same as the direction of displacement, then work is done by the centre of mass. This work is equal to the product of the force and the displacement.
3. Can the centre of mass do negative work?
Yes, the centre of mass can do negative work. This occurs when the direction of the force and the direction of displacement are opposite. In this case, the work done by the centre of mass is negative, indicating that it is losing energy. An example of this is when a person lifts a weight above their head and then slowly lowers it back down. The force of gravity is acting in the opposite direction of the displacement, causing negative work to be done by the person's centre of mass.
4. Does the location of the centre of mass affect the work it can do?
Yes, the location of the centre of mass does affect the work it can do. The centre of mass is the point at which an object's mass can be considered to be concentrated. If the centre of mass is closer to the point of application of the force, then less work is required to cause a given displacement. On the other hand, if the centre of mass is further away from the point of application of the force, more work is required to cause the same displacement.
5. Can the centre of mass do work in a vacuum?
Yes, the centre of mass can do work in a vacuum. The presence of air or any other medium is not necessary for work to be done by the centre of mass. As long as there is an external force acting on the object, causing a displacement of the centre of mass, work can be done. This can be seen in space, where astronauts are able to move objects and do work without the presence of air or any other medium.
