I Can the energy in two waves cancel out? If so, why?
Two waves can indeed cancel each other out through destructive interference, resulting in no observable movement of the medium at certain points, such as nodes in a standing wave. While energy is scalar and cannot be negative, the energy from each wave does not disappear; instead, it redistributes, maintaining conservation of total energy. In regions of destructive interference, energy is transferred to areas of constructive interference, where the amplitude is maximized. The concept of standing waves illustrates that energy remains confined within the system, oscillating between different points rather than being lost. Thus, while waves may appear to cancel at specific locations, the overall energy remains conserved and is merely redistributed throughout the medium.
asada
TL;DR Summary
2 waves that are same amplitude, same frequency and 180 degree out of phase. Can they cancel each other out?
I know the answer would be yes, but why?
In class, I learned that energy is scalar and cannot be negative (at least in undergraduate class). Thus adding two sources of energy should result in a higher level of energy in general. But here for wave, if we have 2 waves that do destructive interference with each other, we won't observe any movement of the medium, thus no energy?
Take the standing wave for example. At the node, since it's stationary, it doesn't have any potential or kinetic energy, but the waves that combine and construct that node obviously have energy in it. We know that using vectors we can explain the "lost" of movement, but how about using the energy theory?
Thank you in advance. I haven't taken any higher Physics class so this is my understanding so far.
Destructive interference doesn’t destroy energy, it just moves it. If you have destructive interference in one place then you have constructive energy in another place. Energy moves away from the region of destructive interference and towards the region of constructive interference. The total energy is conserved.
Likes sophiecentaur, hutchphd and vanhees71
Finally one should always be aware that plane waves are an idealization, not describing accurately real-world phenomena, because their total energy is infinity. One should rather take them as "modes", i.e., a complete set of orthonormal systems of function defined in an appropriate Hilbert space you can use to "Fourier decompose" any real-world wave field.
Likes sophiecentaur and Dale
In a traveling wave, energy flows in the direction of travel. When two harmonic waves travel in opposite directions and form a standing wave, say in a plucked string, energy does not flow and does not "cancel out" either but stays confined between the fixed ends of the string.
The points on the string execute harmonic motion, as if they were masses at the ends of spring. Some have the largest possible amplitude (at the antinodes) and some have zero amplitude (at the nodes). The sum total of the energies of all the oscillators is the energy contained in the standing wave.
asada said:
Summary:: 2 waves that are same amplitude, same frequency and 180 degree out of phase. Can they cancel each other out?
What do you mean by "cancel each other out"? What it means in this context is that if there was only one of the two waves passing through a location, the displacement would be some positive number. Likewise, if we had only the other wave the displacement would be the opposite, it would be the negative of the other wave's displacement. No one is saying those displacements are real. They are just the displacements we'd have if there was just one wave. To get the actual displacement we add the two displacements we would have if there was only one wave.
Same argument applies here. The energies are the energies that each wave would have if it existed separately. In this case, though, adding the two energies doesn't give us the energy of the wave at that location.
The best answer to that is that there isn't an "energy theory" that's relevant. Imagine you had a string with a vibrator at one end. If the vibrator is 'powerful enough' to ensure that the amplitude was constant and if the fixing at the other end were ideal then (if the string was exactly the correct length (say one wavelength) then there would be a node at the middle because the phase of the returning wave would be exactly opposite to the phase of the incident wave (at that point). The two wave displacements would be equal and opposite at all times. Easy so far.
But what about the Energy flow? It would go to the right and then be reflected towards the left and then, when it reached the driving oscillator?? The wave would be the same amplitude and phase as the oscillator so the oscillator could supply no energy to maintain the up down motion of the string. The left moving wave would effectively be reflected and go to the right and so on and so on. The energy 'in' the string would be unchanging - just distributed along the string as sinusoidal vibrations with amplitudes depending on position (i.e. a stationary wave) with no energy in the middle.
In a real system, the string will be 'lossy' and the end termination may not reflect perfectly so the neat standing wave pattern will change. The peaks will be less and the node will be somewhat filled in and there will be some energy at the node.
Likes vanhees71 and Dale
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
