evinda
MHB
- 3,836
Hello! (Wave)
We consider the initial value problem
$$\left\{\begin{matrix}
y'=\lambda y, & t \in [0,\infty), \lambda \in \mathbb{C}, Re(\lambda)<0 \\
y(0)=1 &
\end{matrix}\right.$$
Since $y^n=(1+h \lambda)^n, n \in \mathbb{N}_0$ is the sequence of approximations that the Euler method gives for the above problem, and these approximations remain bounded iff $|1+h \lambda| \leq 1$, we deduce that the region of absolute stability of Euler method at the complex plane is the set $S=\{ z \in \mathbb{C}: |1+z| \leq 1\}$, i.e. exactly the closed disc $|1+z| \leq 1$, with center $-1$ and radius $1$, that is contained at the left complex semiplane $\{ z \in \mathbb{C}: Re z \leq 0 \}$.
If $Re \lambda<0, |\lambda|>>1$, we have to compute with a very small $h$ so that $h \lambda$ is in $S$.
This is a serious disadvantage of Euler method, if we want to apply it at stiff systems, i.e. at systems of the form $x'=Ax$ for which there are eigenvalues $\lambda_{\mu}$ and $\lambda_{\nu}$ of $A$, with negative real part such that $|Re \lambda_{\mu} |>>|Re \lambda_{\nu}|$. For such systems we need to pick very small $h$ (such that $h \lambda_{\mu} \in S)$ to approximate correctly components of the solution, like this one: $e^{\lambda_{\mu}t}$, although these components tend very quickly to $0$ and, practically, aren't significant at the progression of the solution, besides from a small border layer near $t=0$.
Could you give me an example of a stiff system at which we could apply the Euler method, in order to see that it doesn't give right approximations? (Thinking)
y(0)=1 &
