Can the Euler Totient Function Ever Divide n/5 for Any Positive Integer n?
In summary: But $p_{i}$ is a prime, so $p_{i}$ must divide 5 $\pmod 7$. But $p_{i}$ does not divide 5 $\pmod 7$, so $p_{i}$ must divide n $\pmod 5$. But $n$ is not divisible by 5, so $n$ cannot be a multiple of 5.
Poirot1
245
prove that there is no positve integer n such that g(n) dividies n/5, where g is the euler totient function.
Mathematics news on Phys.org
Re: euler totient function proof
I think you misunderstand.
Yep, I surely did. I overlooked the word "divides".
This challenge seems far more harder than it looks like. I don't think I am at the state of attempting it since I am quite sleepy now (11 : 50 here) so I will consider looking at it in the morning if not already being answered till then.
As a note for who thinks \(\displaystyle \phi (n)\) always exceeds n/5 for all n and therefore proving the challenge, I'd like to let you informed about that n/k always exceeds \(\displaystyle \pi (n)\) for any k but it takes large n to do that since the denominator \(\displaystyle O(\log \log(n)) + O \left (\frac{1}{\log \log(n)} \right )\) grows very slowly as the upper bound for totient but still reaches infinity somehow.
I can assure you it is not a difficult challenge.
First we see $n$ has to be a multiple of $5$, otherwise $n / 5$ is not an integer. so $n = 5^l \cdot m$ and $m$ not a multiple of $5$.
Then we have $\phi(n) = 5^{l - 1} 4 \phi(m)$. Now assume $5^{l - 1} 4 \phi(m)$ does divide $m$. Therefore:
$$m = k \cdot 5^{l - 1} 4 \phi(m) \tag{1}$$
Now let the factorization of $m$ be the quasi-general form ($m$ not a power of two, and not a multiple of $5$):
$$m = p_1^{\alpha_1} p_2^{\alpha_2} \cdots p_r^{\alpha_r} ~ ~ ~ ~ \text{with} ~ ~ ~ ~ p_r ~ ~ \text{odd} ~ ~ ~ ~ \text{and} ~ ~ p_1 \ne p_2 \ne \cdots \ne p_r \ne 5$$
Then, it follows that:
$$\phi(m) = \left [ p_1^{\alpha_1 - 1} p_2^{\alpha_2 - 1} \cdots p_r^{\alpha_r - 1} \right ] \cdot \left ( p_1 - 1 \right ) \left ( p_2 - 1 \right ) \cdots \left (p_r - 1 \right )$$
And it should be clear that $(1)$ can never be satisfied, as the prime power $p_r^{\alpha_r}$ cannot divide $\phi(m)$. We have one case left, when $m$ is a power of two. Then:
$$m = 2^e ~ ~ ~ \implies ~ ~ ~ 5^{l - 1} 4 \phi(m) = 5^{l - 1} 2^{e + 1}$$
We see $5^{l - 1} 4 \phi(m) > m$ and so $(1)$ still does not hold.
We reach a contradiction, and Poirot's statement holds true. QED.
Ok I will agree this proof is poorly written but I've jotted it down hastily. Hopefully the underlying idea is still clear (the core concept is pretty much that $\phi(m)$ does not divide $m$). It could probably be generalized for divisors other than $5$, but one must be careful about the special case $m$ is a power of two, which occurs because $\phi(5)$ happens to be a power of two.​
Yes, well done.
My proof: Assume to the contary. Firstly, n is divisible by 5. Let $p_{1}$,...$p_{t}$ be the other prime factors of n.
Then g(n)=n(1-0.2)(1-(1/p_1))...(1-(1/p_t))=4n/5(1-(1/p_1))...(1-1/p_t))
But mg(n)=n/5 for some m so we get:
4m((1-(1/p_1))...(1-1/p_t))=1
Multiplying through by $p_{1}...p_{t}$ gives
$4m(1-p_{1})...(1-p_{t})=p_{1}...p_{t}$
We may assume the primes are in ascending order, and if p_1 is not 2, then the RHS is odd while the LHS is even. Therefore $p_{1}=2$ and upon dividing the equation by this we get:
$2m(1-p_{2})...(1-p_{t})=p_{2}...p_{t}$.
So the LHS is even, whilst the RHS, being a product of odds, is odd - contradiction.
FAQ: Can the Euler Totient Function Ever Divide n/5 for Any Positive Integer n?
What is the Euler totient function?
The Euler totient function, also known as Euler's phi function, is a mathematical function that counts the number of positive integers less than or equal to a given number that are relatively prime to that number.
What is the formula for calculating the Euler totient function?
The formula for calculating the Euler totient function of a number n is: φ(n) = n * (1-1/p1) * (1-1/p2) * ... * (1-1/pk), where p1, p2, ..., pk are the distinct prime factors of n.
How is the Euler totient function related to Euler's theorem?
Euler's theorem states that if a and n are coprime integers, then aφ(n) ≡ 1 (mod n), where φ(n) is the Euler totient function of n. In other words, raising a number to the power of the Euler totient function of n and taking the result modulo n will always give a remainder of 1.
Is there a proof for the Euler totient function?
Yes, there are several proofs for the Euler totient function, including a proof using modular arithmetic, group theory, and number theory. Each proof provides a different perspective on the function and its properties.
What are the applications of the Euler totient function?
The Euler totient function has various applications in number theory and cryptography. It is used in the RSA encryption algorithm, which is widely used in secure communication and online transactions. It also has applications in primality testing, factorization of integers, and generating primitive roots.
