Can the Helium atom be solved by other methods?
  • I
  • Thread starter physwiz222
  • Tags
    Atom Helium
In summary, the Schrodinger equation for helium is an equation that is inseparable due to the potential function V(r12). It can be solved using numerical methods, but finding an exact mathematical expression for the energy eigenvalues and eigenfunctions may require special functions that have not yet been named. Other analytical methods, such as Fourier and Laplace transforms, may not provide a traditional "solution" for the equation, but helium can be described numerically and ab initio with relativistic effects. Overall, exact solutions in terms of elementary functions are rare in physics and may not be feasible for the helium atom.
physwiz222
79
TL;DR Summary
I hear the helium atom schrodinger equation is unsolvable because the electron repulsion term makes it inseparable thus you cant use separation of variables. Can it be solved by other methods besides separation of variables if it can’t why not.
The schrodinger equation for helium is
(−ℏ^2/2me(∇21+∇22)+V(r1)+V(r2)+V(r12))ψ=Eψ
V(r12)=1/(r12-r1) which makes the equation inseparable. Can other methods be used to solve it.
You can approach the solution with numerical methods, as accurately as you want, just like you can calculate the value of ##\sin 1.2## using the power series ##\sin x = x - \frac{1}{6}x^3 + \dots##. But if you attempt to find some exact mathematical expression for the energy eigenvalues and eigenfunctions of helium, it is likely to require some special functions that haven't even been named yet. And there's no guarantee that those same new functions are of any use when writing the solution for the lithium atom, for instance.
Likes mattt and vanhees71
How about other Analytical methods like Fourier, Laplace transform, etc. can those solve it
Likes vanhees71
Probably not in the way you'd call a "solution".
So basically even if u use those methods the wavefunction would not be extractable and the math would not simplify is that what u are saying
I wouldn't be surprised if mathematicians have proved that no solution exists in terms of elementary functions. You could research that online.
In general exact solutions in terms of elementary functions are rare in physics. They are very much the exception.
Well, even the classical problem is not integrable. I'd not expect to find analytical solutions for the quantum problem either, but for sure He can be described numerically and ab initio including relativistic effects.
Likes dextercioby
FAQ: Can the Helium atom be solved by other methods?
Can the Helium atom be solved using quantum mechanics?
Yes, the Helium atom can be solved using quantum mechanics. In fact, quantum mechanics is the most commonly used method for solving the Helium atom due to its ability to accurately describe the behavior of subatomic particles.
Are there any alternative methods for solving the Helium atom?
Yes, there are alternative methods for solving the Helium atom. Some examples include the variational method, the perturbation theory, and the Hartree-Fock method. However, these methods may not be as accurate as quantum mechanics.
How does the solution of the Helium atom using quantum mechanics compare to other methods?
The solution of the Helium atom using quantum mechanics is considered to be the most accurate compared to other methods. This is because quantum mechanics takes into account the wave-like nature of particles, which is essential for describing the behavior of atoms.
Can the solution of the Helium atom using other methods lead to different results?
Yes, the solution of the Helium atom using other methods may lead to slightly different results compared to quantum mechanics. This is due to the different assumptions and approximations made in each method. However, the overall behavior of the Helium atom is still accurately described.
What are the limitations of using other methods to solve the Helium atom?
The limitations of using other methods to solve the Helium atom include the inability to accurately describe the behavior of subatomic particles and the complexity of the calculations involved. These methods may also require more assumptions and approximations, leading to less accurate results.
