Can the Intriguing Harmonic Sum be Solved with Elementary Methods?
In summary, the conversation discusses a trial to prove the sum \sum_{k\geq 1} \frac{H^2_k}{k^2}= \frac{17}{4}\zeta(4)=\frac{17\pi^4}{360}, where H^2_k = \left(1+\frac{1}{2}+\frac{1}{3}+\cdots \frac{1}{k}\right)^2. The authors present solutions to the sum using complicated methods such as contour integration, Fourier series, and Parseal's theorem, but the speaker believes that it can be solved using elementary methods. The conversation also discusses using the formula \psi_0^2(k+1) =
alyafey22
MHB
1,561
This thread will be dedicated for a trial to prove the following
\(\displaystyle \sum_{k\geq 1} \frac{H^2_k}{k^2}=\frac{17}{4}\zeta(4)=\frac{17\pi^4}{360}\)
\(\displaystyle \mbox{where }\,\,H^2_k =\left( 1+\frac{1}{2}+\frac{1}{3}+\cdots \frac{1}{k}\right)^2\)​
In this paper the authors give solutions to the sum and others , but the process is quite complicated and uses contour integration , Fourier series and Parseal's thoerem , ... .
I believe we can solve it using elementary methods .
ZaidAlyafey said:
This method will be dedicated for a trial to prove the following
The harmonic series has no explicit formula for its partial sum. But we can possibly deal with the sum
\(\displaystyle \sum_{j = 1}^k \frac{1}{jk}\)
I don't recognize the series, but if there is one and we can break it down into partial sums I think there might be an outside chance of an induction proof.
Possible do you think?
-Dan
I am thinking of using the formula
$$\psi_0^2(k+1) = (H_k -\gamma)^2$$
or possibly solving the integral
\(\displaystyle \left( \int^1_0 \frac{1-x^n}{1-x}\, dx \right)^2 \)
-Dan
I don't possibly get your idea , could you elaborate ?
The "inner" sum (before we square it and take the sum of that) is the 1/jk summation. I was thinking if we could get an explicit formula for that in terms of k we might be able to get a partial sum expression to sum over the square of and proceed inductively. If it works the outer sum would still be nasty as all (Swear) to compute, but it might be a way forward.
-Dan
- - - Updated - - -
ZaidAlyafey said:
\(\displaystyle \left( \int^1_0 \frac{1-x^n}{1-x} \right)^2\, dx \)
There's a typo here. What integral is this?
-Dan
We can use the following generating function
\(\displaystyle \sum_{n\geq 1} H^2_n x^n = \frac{\log^2(1-x)+\operatorname{Li}_2(x)}{1-x}\)
\(\displaystyle \sum_{n\geq 1} H^2_n x^{n-1} = \frac{\log^2(1-x)}{1-x}+\frac{\log^2(1-x)}{x}+\frac{\operatorname{Li}_2(x)}{1-x}+\frac{\operatorname{Li}_2(x)}{x}\)
By integrating we get
\(\displaystyle \sum_{n\geq 1}\frac{ H^2_n }{n}x^{n} = -\frac{\log^3(1-x)}{3}+\int^x_0 \frac{\log^2(1-x)}{x}\, dx+\int^x_0 \frac{\operatorname{Li}_2(x)}{1-x}\, dx+\operatorname{Li}_3(x)\)
\(\displaystyle \int^{x}_0 \frac{\operatorname{Li}_2(x)}{1-x}\, dx= -\log(1-x) \operatorname{Li}_2(x)- \int^x_0 \frac{\log^2(1-x)}{x}\)
Hence we have
\(\displaystyle \sum_{n\geq 1}\frac{ H^2_n }{n}x^{n} = -\frac{\log^3(1-x)}{3}-\log(1-x) \operatorname{Li}_2(x)+\operatorname{Li}_3(x)\)
\(\displaystyle \sum_{n\geq 1}\frac{ H^2_n }{n^2}x^{n} = -\frac{1}{3}\int^x_0 \frac{\log^3(1-x)}{x}\, dx+\frac{ \operatorname{Li}^2_2(x)}{2}+\operatorname{Li}_4(x)\)
Of course this a generalization of the harmonic sum , an attempt to solve the integral will be made later .
Let us solve
\(\displaystyle \int^x_0 \frac{\log^3(1-t)}{t}\, dt\)
If we start by parts we get
\(\displaystyle \int^x_0 \frac{\log^3(1-t)}{t}\, dt = \log^3(1-x)\log(x) +3 \int^x_0 \frac{\log^2(1-t) \log(t)}{1-t} \, dt \)
Integrating by parts again we get
\(\displaystyle \int^x_0 \frac{\log^3(1-t)}{t}\, dt = \log^3(1-x)\log(x) +3 \left(\log^2(1-x)\operatorname{Li}_2(1-x)+2 \int^x_0 \frac{\log(1-t) \operatorname{Li}_2(1-t)}{1-t} \right)\)
Simplifying we get
\(\displaystyle \int^x_0 \frac{\log^3(1-t)}{t}\, dt = \log^3(1-x)\log(x)+3 \log^2(1-x)\operatorname{Li}_2(1-x)+6 \int^x_0 \frac{\log(1-t) \operatorname{Li}_2(1-t)}{1-t}\, dt \)
By parts for the third time
\(\displaystyle \int^x_0 \frac{\log^3(1-t)}{t}\, dt = \log^3(1-x)\log(x)+3 \log^2(1-x)\operatorname{Li}_2(1-x)-6 \operatorname{Li}_3(1-x) \log(1-x) +6\operatorname{Li}_4(1-x) -6\zeta(4)\)
So that becomes
\begin{align}
\sum_ {n\geq 1}\frac{ H^2_n }{n^2}x^{n} &= \frac{\pi^4}{45}-\frac{1}{3}\log^3(1-x)\log(x)- \log^2(1-x)\operatorname{Li}_2(1-x)+2 \operatorname{Li}_3(1-x) \log(1-x) \\& \, -2\operatorname{Li}_4(1-x)+\frac{ \operatorname{Li}^2_2(x)}{2}+\operatorname{Li}_4(x )
\end{align}
Putting $x =1$ most of the terms will go BAAAA... m and we are left with
\(\displaystyle \sum_{n\geq 1}\frac{ H^2_n }{n^2} =\frac{\pi^4}{45}+\frac{\zeta^{\, 2}(2)}{2}+\zeta(4)=\frac{\pi^4}{45}+ \frac{\pi^4}{72}+\frac{\pi^4}{90}=\frac{17 \pi^4}{360}\)
Wasn't that nice !
FAQ: Can the Intriguing Harmonic Sum be Solved with Elementary Methods?
What is "Intriguing Harmonic Sum"?
Intriguing Harmonic Sum is a mathematical concept that involves the sum of the reciprocals of a sequence of numbers. It is often used to study the convergence or divergence of a series.
What is the formula for calculating "Intriguing Harmonic Sum"?
The formula for calculating the Intriguing Harmonic Sum is Hn = 1 + 1/2 + 1/3 + ... + 1/n, where n is the number of terms in the sequence.
What is the significance of "Intriguing Harmonic Sum" in mathematics?
"Intriguing Harmonic Sum" has many applications in mathematics, including in calculus, number theory, and physics. It is also used to study the behavior of infinite series and the convergence of certain mathematical functions.
Are there any real-world applications of "Intriguing Harmonic Sum"?
Yes, "Intriguing Harmonic Sum" has real-world applications in fields such as engineering, economics, and physics. It can be used to calculate the total resistance in an electrical circuit, estimate the average cost of goods in economics, and analyze the behavior of sound waves in physics.
What are some common misconceptions about "Intriguing Harmonic Sum"?
One common misconception is that the sum of the reciprocals of a sequence always converges. In reality, some sequences can produce a divergent sum. Another misconception is that the sum of the reciprocals of all natural numbers is infinite. In fact, this sum is known as the harmonic series and is divergent.
