Can the law of conservation of energy of be broken?
In summary: But that is what the is really happening in the world, so if the cat is actually alive, we can go in and see it. But if we see it, then we are changing the quantum state of it. So it is both alive and dead, but not at the same time. That was the whole point of the thought experiment. It is meant to show the absurdity of applying quantum mechanics to macroscopic objects. In reality, the cat would either be alive or dead, not both. The superposition of states is simply a mathematical tool to describe the probabilities of different outcomes.In summary, according to the Heisenberg Uncertainty Principle, particles can have a fluctuation in their energy levels for a short amount of time as
Lunct
133
A consequence of Heisenberg's Uncertainty principle is that particles energy level can fluctuate their amount of energy, e, for a short amount of time, t, as long as e x t < h/4pi (where he is = to Planck's constant). So does that not violate the law of conservation of energy?
Doubt it, wouldn't that break Noether's theorem?
I don't think the answer you got in the previous thread can be improved on as a general answer:
https://www.physicsforums.com/threa...rg-uncertainty-principle.916740/#post-5777389
A good start at something more specific might be to give the exact source where you got this:
Lunct said:
That's still rather vague. This has been answered a few times on the stack-exchange, i'll link you the links see if they help.
https://physics.stackexchange.com/q...ple-violate-the-law-of-conservation-of-energy
https://physics.stackexchange.com/q...conservation-limited-by-uncertainty-principle
http://www.physlink.com/education/askexperts/ae605.cfm
For the above link, it appears to be a violation but it cannot actually be physically measured.
https://www.researchgate.net/post/Does_the_uncertainty_principle_violate_the_conservation_of_energy_law
Likes Lunct
I suspect the word "fluctuation" is the problem here. In quantum mechanics, it doesn't imply variation with time. In this situation it's more like a synonym for "uncertainty" or "indefiniteness".
In the end, the energy that we actually measure is always conserved. Same for other conserved quantities like momentum. What "really happens", "inside" the ##\Delta E## or ##\Delta p## or whatever, before we make a measurement, is unknowable. Quantum mechanics is silent about what is "really happening" with unmeasured or unmeasurable quantities. This is the province of interpretations of quantum mechanics, about which people argue endlessly, here and elsewhere.
Likes bhobba, QuantumQuest, A. Neumaier and 1 other person
Lunct said:
from this book
This is a pop science book, which means that, even though it's written by scientists, it's not held to the same standards as a textbook or peer-reviewed paper. Which means it's not a good source to learn the actual science from; at best it can whet your appetite to go and learn the actual science.
Likes phinds, bhobba and Lunct
So it is like Schrodinger's cat in that the energy levels do not actually change, it is just that we are unsure on it, so it is thought as a fluctuation in energy. Like Schrodinger's cat is probably not dead and alive, but it is just simply easier to think as it that way.
Exactly:
http://phys.columbia.edu/~nicolis/NewFiles/Noether_theorem.pdf
Its also a bit circular - energy not conserved - you don't have time symetry in your system and conversly.
This is in fact a big problem for GR since it deals with non flat space-times.. That means time may not have symmetry ie the same experiment you do does not necessarily give the same results at different times, so Noether breaks down. It leads to energy not being able to be defined in the usual way as the conserved quantity from time symmetry in GR:
http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
Thanks
Bill
The easiest way to think about Schrodinger's Cat is that everything is classical after the detection of the atomic decay. That of course means the cat can never be in a state of dead an alive because those kind of superposition's can't occcur classically. The kind of superposition's that can occur in the ordinary world are very contrived eg the famous double slit but that is a whole new thread.
Thanks
Bill
Note carefully, though, that this is only an issue for global definitions of energy, i.e., "how much energy is there in total in some volume"? It is not an issue at all for local conservation of energy: in GR, this is guaranteed by the fact that the covariant divergence of the stress-energy tensor is zero (which is in turn a consequence of the Einstein Field Equation and the fact that the Einstein tensor obeys the Bianchi identities).
In other words, even in a curved spacetime, energy can't be created or destroyed locally. There is only an issue when you try to add up all the local pieces of energy to get a global quantity. There are multiple ways of doing this in GR, but all of them only work in special classes of spacetimes (the ADM and Bondi energy are only defined for asymptotically flat spacetimes, and the Komar energy is only defined for stationary spacetimes--the latter is the closest analogue to "the conserved quantity from time symmetry") or for special choices of coordinates (the various energy pseudo-tensors).
The Baez article you linked to expresses this distinction as the differential (local) vs. integral (global) form of energy conservation.
Likes bhobba
There's more going on here than that; the physics of a macroscopic system like a cat is very different from the physics of a single quantum particle subject to the uncertainty principle.
You should be aware that anything you've heard about Schrödinger's cat that didn't come from a college-level textbook or peer-reviewed journal article is almost certainly wrong. When Schrodinger suggested this thought experiment, he was pointing out a problem that arose in the then-current (1930 or thereabouts) understanding of quantum mechanics, not trying to argue that the cat would be in a superposition of dead and alive. It took a few more decades to resolve the problem, but unfortunately by then the idea of the neither/both dead and alive cat had leaked into the popular imagination and lives on as a stubborn urban legend.
Two books that you might want to try:
1) "Where did the weirdness go?" by David Lindley is a layman-friendly and math-free description of the most important post-1930 development.
2) "Sneaking a look at god's cards" by Giancarlo Girardi is a good non-rigorous explanation of quantum mechanics as applied to subatomic particles; understanding QM at this level is necessary to properly answer your question about energy conservation. A high school student can get through this book with some effort.
Likes bhobba
Energy conservation is so important in physics that if there were some experiment where it would appear to be violated, physicists would rather imagine some 'invisible' form of energy that the missing energy is being converted to, than discard the conservation law. One example of this is the explanation of beta-decay with an electron neutrino (which was impossible to observe at the time when it was first postulated).
An isolated system has a Hamiltonian operator from which the possible total energy values are deduced, and the probabilities of each of these values remain constant for an indefinite time, as does the statistical expectation value of the total energy.
Related to Can the law of conservation of energy of be broken?
1. Can energy be created or destroyed?
According to the law of conservation of energy, energy cannot be created or destroyed. It can only be transformed from one form to another.
2. What is the law of conservation of energy?
The law of conservation of energy states that energy cannot be created or destroyed, but it can be transformed from one form to another.
3. Is the law of conservation of energy always true?
Yes, the law of conservation of energy is a fundamental law of physics and has been extensively tested and verified. It is considered to be one of the most fundamental principles of the universe.
4. Can the law of conservation of energy be broken under certain circumstances?
No, the law of conservation of energy cannot be broken. It is a fundamental law of nature and applies to all physical systems. However, there may be situations where it appears that energy is not conserved, but this is due to a lack of understanding or accounting for all forms of energy involved.
5. Are there any exceptions to the law of conservation of energy?
No, there are no known exceptions to the law of conservation of energy. It has been observed and verified in all physical systems and is a fundamental principle that governs the behavior of energy in the universe.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Mechanics
