Can the mass flow rate change?
In summary, the conversation discusses the relationship between mass flow rate of air and the rpm of a propeller connected to an engine through a small tube. The question is unclear and the speaker requests a visual aid for clarification. However, if we assume a simple setup of an engine and a propeller, the mass flow rate will increase as the rpm of the propeller increases.
JBM1234
Hello everyone,
Can the mass flow rate of air by a propeller connected to an engine through a small tube change if the rpm of the propeller is increased?
I'm afraid your question is very unclear. First I thought a ducted fan. Then a metal tube shaft to the engine. Can you please post a picture or a sketch of what you mean? Use the UPLOAD button at the bottom right of the post edit window to post a picture.
If we assume you just have an engine connected to a propeller. Then yes. The faster the engine spins the propeller the greater the mass flow rate.
Related to Can the mass flow rate change?
1. Can the mass flow rate change in a closed system?
Yes, the mass flow rate can change in a closed system. This can occur due to changes in temperature, pressure, or the addition/removal of substances within the system.
2. What factors can affect the mass flow rate in a system?
The mass flow rate can be affected by factors such as the size and shape of the system, the density and viscosity of the substance flowing through the system, and the presence of any obstructions or restrictions in the flow path.
3. How is the mass flow rate calculated?
The mass flow rate is calculated by multiplying the density of the substance by the velocity of the flow and the cross-sectional area of the flow path. This can be expressed as the equation: mass flow rate = density x velocity x area.
4. Can the mass flow rate be increased or decreased?
Yes, the mass flow rate can be increased or decreased by changing the velocity of the flow, altering the density of the substance, or adjusting the size of the flow path. Additionally, adding or removing substances from the system can also affect the mass flow rate.
5. How does the mass flow rate impact the efficiency of a system?
The mass flow rate can impact the efficiency of a system by affecting the rate at which substances are transported through the system. A higher mass flow rate can result in faster processing times and increased productivity, while a lower mass flow rate may lead to longer processing times and decreased efficiency.
  • Mechanical Engineering
