Can the temperature of an object be derived from the EM Wave
In summary: You'll need to use a contact thermometer or a 'fast' thermometer, which measures the temperature of a small volume of material to get a good reading.In summary, the temperature of an object can be determined by studying the spectrum of EM radiation it emits, with the peak frequency increasing as the temperature of the object increases. However, additional information about the object and its emittance ratio may be needed for an accurate measurement.
poot lovato
Can the temperature of an object be derived from the EM Waves it emits?
I know that everything having a temperature over absolute zero emits thermal radiations. The hotter the object gets, the higher the frequency of the wave goes.
But for example if I have a hammer which emits a wave xHz, will I be able to calculate it's temperature by merely studying the waves emitted? (something to do with energy?)
Please help I feel clueless.
You can indeed measure the temperature by measuring the emitted spectrum of EM radiation from the object. Note that all objects emit a broad range of frequencies, with the peak frequency (frequency with the largest proportion of energy) increasing as the temperature of the object increases. Here's a calculator you can play around with to see how the emitted wavelength and frequency reacts to changes in temperature.
You'd also need something capable of measuring the radiation. For a room temperature object, the emitted radiation falls mostly in the long-wavelength infrared region, so you'd need a sensor capable of seeing that.
Likes poot lovato
Hi.
Practically, infrared thermometer already has been used with a principle of the blackbody radiation. Maybe you know that in a hospital we can easily see that thermometer. Maybe you know that Stefan-Boltzmann law says the power of radiation per unit surface.
Thank you.
(if you have questions more, send me email to [e-mail address removed by moderator], and if you are a native speaker and rectify my English error, I would really appreciate it because I am learning English.)
It's the only possible way of determining the surface temperature of the Stars we see. You assume that the emitter is 'black body' and the emission spectrum will tell you the temperature. Red hot and white hot?
You need some additional information about the object to do that, otherwise you can just calculate a minimal temperature. The problem: not every object is a blackbody. Most objects are good approximations to that in the infrared range, so infrared thermometers work nicely, but some objects emit significantly less radiation than a black body would do, and their emittance ratio relative to a blackbody can have a shape that mimics a body at a lower temperature.
If you put a warm metal in a cold room and try to measure its temperature with an infrared thermometer, you'll underestimate its temperature, because the metal won't emit much radiation on its own and the power of reflected infrared radiation from the room is low as well.
Related to Can the temperature of an object be derived from the EM Wave
1. Can the temperature of an object be determined using EM waves?
Yes, the temperature of an object can be derived from the EM waves it emits or absorbs. The intensity and frequency of the EM waves can provide information about the temperature of the object.
2. How does the temperature affect the EM waves emitted by an object?
The temperature of an object affects the intensity and frequency of the EM waves it emits. As the temperature increases, the intensity and frequency of the EM waves also increase.
3. Is it possible to determine the temperature of an object using only one type of EM wave?
No, it is not possible to determine the temperature of an object using only one type of EM wave. Different types of EM waves have different frequencies and wavelengths, and they interact with matter in different ways. Therefore, a combination of EM waves is needed to accurately determine the temperature of an object.
4. Can the temperature of an object be derived from the EM waves it absorbs?
Yes, the temperature of an object can also be derived from the EM waves it absorbs. The amount and frequency of EM waves absorbed by an object can provide information about its temperature.
5. Are there any limitations to determining the temperature of an object using EM waves?
Yes, there are limitations to determining the temperature of an object using EM waves. Factors such as the distance between the object and the detector, the composition of the object, and the presence of other sources of EM waves can affect the accuracy of the temperature measurement.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
