Can the Volume of a Sphere be Calculated Using its Surface Area and Radius?
  • MHB
  • Thread starter wolfsprint
  • Tags
    Change Time
In summary, the volume of a sphere is = v cm^3, it's radius is = r cm, it's surface area is = x cm^2, and proves that: dv/dt = 1/2 r.dx/dt.
wolfsprint
The volume of a sphere is = v cm^3, it's radius is = r cm, it's surface area is = x cm^2, prove that : dv/dt = 1/2 r.dx/dt
Express the volume and the surface area through r(t) and differentiate them.
I tried and I couldn't, can you please show the work?
Well, start by showing your work in expressing the volume and the surface area through the radius. You should not do it yourself; you should just find the formulas in a textbook or online. Then what exactly is your difficulty in differentiating? You need to use the chain rule because the volume is a function of r and r is a function of t.
The only equation i managed to find is v=4/3 "pi" r^3 which is he volume of the sphere.
So if we say that the surface area = x ,then
V=1/3 r . X
But then when i differentiate it it turns out like this ,
Dv/dt = 1/3 dr/dt . Dx/dt , and that prove needs dv/dt = 1/2 r . Dx/dt
First, do not mix uppercase and lowercase letters, such as X and x. In mathematics, they often denote different entities.
V=1/3 r . X
Since you found the relationship between v and x, you must know that $x = 4\pi r^2$, so this is the second equation that you have. You can also find this in Wikipedia.
In post #2, I recommended expressing both v and x only through r and then differentiating them as compositions v(r(t)) and x(r(t)). Here you expressed v through x and r.
I still don't understand , what do you by "expressing"?
By expressing $v$ and $x$ through $r$ I mean finding formulas containing constants and $r$ only that give the values of $v$ and $x$. These formulas are $v=\frac{4}{3}\pi r^3$ and $x=4\pi r^2$. Then we have $\frac{dv}{dt}=4\pi r^2\frac{dr}{dt}$. Similarly, find $\frac{dx}{dt}$ (keep in mind that $r$ is a function of $t$, i.e., $x(t)$ is a composite function $x(r(t))$, just like $v(r(t))$) and compare the results.
Thanks a lot but i still didnt get what you are trying to tell me , I've got all these equations on the paper and i tried to substitute each in the original but it just won't get the right answer! the fact that dr/dt exists is not right :(:confused:
So, we established that
\[\frac{dv}{dt}=4\pi r^2\frac{dr}{dt}\tag1\]
Next, since $x=4\pi r^2$, we have
\[\frac{dx}{dt}=8\pi r\frac{dr}{dt}\tag2\]
Comparing the right-hand sides of (1) and (2), we see that $\frac{dv}{dt}=\frac{1}{2}r\frac{dx}{dt}$.
Using the given variables, we have:
The volume of the sphere is:
(1) $\displaystyle v=\frac{4}{3}\pi r^3$
The surface area is:
(2) $\displaystyle x=4\pi r^2$
We are asked to show:
$\displaystyle \frac{dv}{dt}=\frac{1}{2}r\frac{dx}{dt}$
Now, differentiating (1) and (2) with respect to time t, solving both for $\displaystyle \frac{dr}{dt}$ and equating, what do we find?
Thanks alot! i can't believe i missed that
FAQ: Can the Volume of a Sphere be Calculated Using its Surface Area and Radius?
1. What is a related time change problem?
A related time change problem is a type of mathematical equation that involves calculating time differences or changes between two or more events or situations.
2. Why is solving related time change problems important?
Solving related time change problems is important in many fields, including physics, engineering, and finance. It allows us to accurately measure and predict changes in time, which is crucial for making informed decisions and understanding the world around us.
3. What are some common strategies for solving related time change problems?
Some common strategies for solving related time change problems include using the formula distance = rate x time, creating a timeline or chart to visualize the changes, and breaking the problem down into smaller, more manageable parts.
4. Can related time change problems have more than one solution?
Yes, related time change problems can have multiple solutions. This is because there can be different ways to interpret the given information and different approaches to solving the problem. It is important to carefully check and verify all solutions to ensure accuracy.
5. How can I improve my problem-solving skills for related time change problems?
Practice and familiarity with different types of related time change problems is key to improving problem-solving skills. It can also be helpful to work through problems with others and to seek out resources such as textbooks or online tutorials for additional guidance and practice.
